04-27-2010, 10:11 AM | #2121 |
No, you won't need a BEC. The throttle curves are not yet adjustable, but we are working on implementing this into a future update.
04-29-2010, 04:17 PM | #2122 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
do i need lipo's to run tour torquemaster combo?
04-30-2010, 07:47 AM | #2123 |
Rock Crawler Join Date: Feb 2010 Location: costa rica
| Order #5007
Hi, I was just wonering when will it ship out???? |
04-30-2010, 08:59 PM | #2124 |
Quarry Creeper Join Date: Aug 2008 Location: 5280'
i got a 7t puller and it is all wore out! is there a way that i could send it in and have it rebulid? i am trying to work with the person i got it from but if he does not help me out is there a way to do that? and about how much would it run? thanks!
05-16-2010, 12:25 AM | #2125 |
Rock Stacker Join Date: May 2010 Location: clintonville
| 1/8th scale RC4WD ROCKBULL
what motors can i use on this crawler it wieghs about 20LBS with wheel wieghts wanted to know if a holmes motor would work running 2 mamba maxes also planning to put larger tires and rims on it the demolishers from RC4WD THANKS ANY HELP WOULD BE APPRECIATED
05-16-2010, 06:25 PM | #2126 |
Quarry Creeper Join Date: Dec 2008 Location: San Diego
| 1.9 motor
hey I order a mrc motor and it dose not work i emailed you and have had no reply. need help plz
05-20-2010, 06:40 PM | #2127 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
I am experiencing a weird "glitch" when I turn right ONLY. I am running the HH tm brxl with two 7950th's and a bec on each. Nomadio 4ch radio on my super. I have changed the servo's direction and then the glitch is on the left. Running the Holmes Hold with 40% drag. Epa's are set at 85 and 90. Not sure what to look for so any suggestions would be great.
05-20-2010, 10:05 PM | #2128 | ||||
For some reason I wasn't getting updates on this thread. I was wondering why it seemed dead... Nope, but you will need the CAstle link to turn off the lipo cutoff. Quote:
Holmes Hobbies 716 W. Sexton rd. Columbia, MO 65203 Quote:
05-21-2010, 10:00 AM | #2129 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
I recently went Lipo and I finally feel confortable with charging, balancing, etc., but not discharging. I have read some places its not worth my time, or that I should just run the pack down on my rig to LVC. I've looked around the forum and I'm at a loss. Any help is appreciated!!
05-21-2010, 10:03 AM | #2130 | |
05-21-2010, 10:03 AM | #2131 | |
05-21-2010, 10:28 AM | #2132 | |
05-21-2010, 05:29 PM | #2133 |
| 1/8th scale rockbull rc4wd
what type of outrunner i had 2 75 turn integy motors in it and one is smoked brand new rig what do you recommend
05-24-2010, 03:38 PM | #2134 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
Hey John, Do you think a Torquemaster Handwound Pro in a 30t with your Torquemaster BR-XL ESC on 3s would run satisfactory in a Losi Comp Crawler? Reason I ask is that I came across a good deal on an LCC but would like to use my present motor/ESC comb in it... |
05-27-2010, 11:00 AM | #2135 |
Rock Stacker Join Date: May 2010 Location: N/A
Hi, I recently purchased a cobalt 500 11t and did not get the motor plate with it. Was it supposed to come with that or did I misunderstand the add on your webpage? I have an axial shafty with a 10tooth pinion 87t spur. Will this motor be ok on 9.6v? Thanks for your time. |
05-27-2010, 11:38 AM | #2136 | ||||
05-27-2010, 12:03 PM | #2137 |
Thanks for the quick response. I sent you an email.
05-27-2010, 08:44 PM | #2138 |
| rc4wd 1/8th scale rockbull help
thanks john ill go ahead and order the revolver outrunners SHOULD I RUN GEAR REDUCTION UNITS ALSO AND WHAT RATIO IF SO wanted to also ask im running 2 hitech 7950 servos and they seem like they have no torqe im running a castle creations bec @7volts dont want to run any higher because im running a 2.4ghz airtronics m11 radio and reciever and it only suppose to run 6.6volts regulated WHAT DO YOU THINK WOULD BE THE PROBLEM this thing does wiegh 20 lbs
05-27-2010, 09:24 PM | #2139 |
| 1/8th scale rockbull issues
was running 2 mamba max escs when the esc in the rear kept losing throttle position and i would have to reprogram it and when i ran 1 esc or 2 the rear motor had no power running them on 1 channel with a y cable could that be the problem
05-28-2010, 07:43 AM | #2140 |
Quote: With some advanced timing on the motor, it would kick ass. Thanks John!! |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
