06-29-2010, 10:55 AM | #2161 |
For the heat, some airflow would indeed help. As long as the fan runs off 12v, you would be fine to run it off the 3 cell lipo.
07-01-2010, 08:22 PM | #2162 |
Pebble Pounder Join Date: Jan 2010 Location: Arcade, NY
I am planning on getting a Cobalt Puller 500 for a scale build I am just starting, and I am wondering if the Mamba Max Pro is efficient enough to run it properly? Thanks ^^ |
07-01-2010, 09:27 PM | #2163 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| I've been running a 12t 500 puller in my scaler with a Mamba Micro on 3-cell lipo for over a year and a half with no problems....you will have NO problems with your setup.
07-03-2010, 02:59 PM | #2164 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
Hey John, I burned up a HS-225MG dig servo with my new br-xl setup on 3s 1350 25C lipos... I also run the HS-7995TG for steering. Does the BEC onboard the ESC not have the ability to run with 2 servos and it overloaded it or something? or is it just that the mini servos aren't capable of handling the voltage put out by the BEC? I just bought a HS-5645 for my dig servo and don't want the same thing to happen to it. |
07-05-2010, 08:57 AM | #2165 |
The BEC won't burn up the servo, but your setup can. Most likely your dig servo was binding at the end of travel and was pulling too many amps. I would suggest putting a spring cush on the servo travel, or adjusting the endpoints so that it does not bind or hum at either end of the servo travel.
07-11-2010, 06:51 PM | #2166 |
Newbie Join Date: May 2010 Location: USA
hello, i was looking around your web site and found the cobalt puller 500 motors i was wondering if they would be a good replacement for my artr bully i have two tekin fx-r esc with two integy v11 35 turn motors, and i am running it off of 7.4v. I was wondering which of the two turns (11 or 12) would be a good replacement so it would have around the same speed and power and what gearing i should use. plus will the pullers give me better drag brake? THANKS |
07-12-2010, 12:50 AM | #2167 |
Newbie Join Date: Feb 2010 Location: Calgary
Looking for a 35t to 45t, with adjustable timing for a non crawler project, and these look like they'll fit the bill. For that matter I wish I had heard of you while I was building my AX10, when my Tekin hand wound needs replacing I'll look to you for help! Do you know what amperage your TorqueMaster Pro Handwounds will draw at best efficiency with 11.1v in that turn range? Will be going into a rwd scale runner with 3.5" tall tires, and likely 8.17:1 final drive ratio, powered with a tekin fx-r pro and 2 - 20c 1200mah 3s lipo in parallel. Only one pack if the amp draw is low enough. I can play with final drive ratio as needed as well. Last edited by Formiga; 07-12-2010 at 12:53 AM. Reason: bad typing! |
07-19-2010, 10:10 AM | #2168 |
Newbie Join Date: Feb 2010 Location: Northern CO
I'm looking at order the 25C 1300mah lipo battery for my MRC. I was curious if I order it with the Deans connector option will the order be delayed. I was planning to order today in hopes I could have them by the end of the week (7/23).
07-19-2010, 10:24 AM | #2169 | ||
The order won't be delayed with the Deans installed. I just got back from Colorado, so I am a bit backed up with orders currently. I should be able to mail all out by tomorrow or wednesday morning however. | ||
07-19-2010, 10:38 AM | #2170 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
Hey JRH....I'm sure loving my BR-xl esc's!! I have 4 of them now...I went to rojo's this weekend and had some issues though... here is my rig specs 4pk dual BR-xl's 2x 2s TP 850 lipos ran to make them small 4s lipos CC bec on my 1st course I noticed some stalling on my front end...I figured motor was going south..but then on my 2nd course I was driving along and everything just stopped...no power any where..no rear power, no steering and no front power..I got down to look around at the rig and my lipo went up in smoke!!! so I take the DNF on course #2..go to the pit to see whats up and at this point I still was thinking front motor issues..so I unplug the front motor from the esc and plug in another set of battery's..soon as the power touch's the deans my second pair of lipos poof out smoke too...$80 bucks in lipos!! so now i'm thinking the Front ESC is the problem...I start isolating the problem..power up the front esc with an old 3s lipo and it smokes too!!(but I tested the lipo later and it still works) so lucjy for me I had my spare rig with me and I pulled one of the BR-xl's from it...wire it up and all is fine....so I was able to finish the comp but i'm totally bummed at the huge expensive electronics problem I'm wondering if there is some issue that might have caused this?? it was a VERY expensive esc issues.. $100 for the Br-xl $22x4 for my 4 burned up tp lipos=$88 pretty bummed about it I know most electronics dont carry much warranty but I'm wondering what if anything you can do to help me?? (man I was praying to win one of your raffle ESC's.....but I did not win one..) thanks Mark |
07-19-2010, 10:41 AM | #2171 |
We can get the ESC replaced for you no sweat, send me an email with your contact info and we can get it sorted out. Sorry that you had troubles during a comp with it! Sometimes these things happen. Frequently it can be conductive dust/ rocks getting under the heatsink and shorting out the FETs.
07-20-2010, 07:19 PM | #2172 |
| HH Mini Torque Master
is there any break in required on this motor for the MRC? Thanks |
07-22-2010, 09:05 AM | #2173 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Anything ever happen with those sensored outrunners? Was trying to find the posts on it but nada. |
07-23-2010, 12:54 PM | #2174 |
Got my torque master mini and was wondering what pinion to run? Currently I am running a Reedy stump puller with at 10t pinion. I want to run the HHTMM. HELP!!! Thanks |
07-23-2010, 01:06 PM | #2175 | |
| Nope, I break them in for you! Just be sure to add in some advanced timing for longest motor life. Quote:
I would start with the 10t and see how you like it. Can't really go wrong with anything you choose, as long as it isn't huge. | |
07-25-2010, 04:46 PM | #2176 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
Hey I was just checking out your site and was wondering if you had an ETA on when more torquemaster combos might be available? Specifically I'm lookin to get a 45T. BTW, after scanning through this thread I gotta say I am thoroughly impressed with the level of support you provide for your stuff and for crawlers in general. |
07-25-2010, 10:09 PM | #2177 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
so i bought a torquemaster BR-XL (waterproof verion) back in march, just got around to putting it in my scaler about a month ago. maybe has 5 2200mah 3s packs through it, and while using it today it went up in smoke, haven't even got to touch water with it yet, luckily unplugged the battery and ripped the esc out of the rig before it burnt anything. this is what it looks like now lol loved this esc. really just wondering if this is common or if i just got a lemon, cause i would like to get another one. |
07-25-2010, 10:35 PM | #2178 | ||
Shoot me an email, we can get you taken care of no sweat. | ||
07-26-2010, 11:00 AM | #2179 |
Quarry Creeper Join Date: Dec 2009 Location: LAWRENCEVILLE
| Waterproof / Fast ESC
I just built my first scaler and used Losi axles since a "dragbreak" is built in. It has an old Rooster ESC 2s lipo only and a 35T HH. Needless to say it's much much slower than I thought it would be. I wanted to know if your waterproof setup with a 6S lipo would be similar to a VXL brushless set-up on 3S? I have a few 3S laying around I can use but would need to buy 6S to go with the BR-XL so total investment would be the same? Long term I want to be able to do TTC type comps and water crossings are always involved. Any opinion you can share would be greatly appreciated. |
07-26-2010, 11:07 AM | #2180 |
I wouldn't push 6s through the 35t motor. Maybe 3s or 4s instead. You can put two 3s packs in series for 6s, it is what most people do.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
