12-31-2007, 01:55 PM | #221 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
i have a deans plug that lets me run 2 matched mah pacs in series , can i use lipo instead of my stick packs? thanks for all the info
12-31-2007, 03:32 PM | #222 |
| Yes, as long as you have an ESC that supports lipo packs. Also, make sure the packs are the same type and age as well as both equally charged.
12-31-2007, 10:32 PM | #223 |
Quarry Creeper Join Date: Jul 2007 Location: Mac
| Cobalt 5T, MM and 3cell lipo... holy crap, batman!!!
just got the ax-10 put together, dropped in the cobalt 5T, and made a few laps around the living room. talk about some serious power!!! picked it up to see how things were holding up and noticed things smelled a tad warm. temped the can at 195 and the comm at 214! JRH, is this normal?
12-31-2007, 11:57 PM | #224 |
Landy mad Join Date: Jun 2005 Location: Newcastle, England, UK
| esc interference with castle bec unit
I'm trying to run one of the Castle BEC's with my Mtroniks Viper SSR speed control and get extreme interference. I have noticed that the slow speed control is nowhere near as smooth as when running the ESC's BEC. I also suffer from the steering servo glitching like mad. If I run it through a Tekin Rebel 2 I do not have these issues. It makes no difference if I run on 7.2 or 9.6V. The motor turns also make no difference. I want to run the SSR's as they have zero reverse delay and give 100% reverse as well as forwards power. Any idea what the problem could be |
01-01-2008, 01:45 AM | #225 | |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
01-01-2008, 11:21 AM | #226 | ||
You didn't say what radio you were using. My guess is that your radio doesn't like the BEC. You can either isolate the BEC power to the servo, try a ferrite ring around the BEC RX lead, or try moving your antenna and RX away from the other electronics. | ||
01-01-2008, 11:46 AM | #227 | |
I'm confused about it being the radio as I mentioned I do not have the problems with the Tekin Rebel 2. Any other ideas? Thanks | |
01-01-2008, 12:24 PM | #228 | |
01-01-2008, 01:38 PM | #229 | ||
Try moving the RX away from everything, or try isolating the BEC to only the servo with a Y harness that only passes the signal wire from RX to servo. What voltage do you have the CC BEC set to? Quote:
01-01-2008, 02:58 PM | #230 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
how many volts is the scorpion 3032-8 rated for? Thanks |
01-01-2008, 03:10 PM | #231 |
3s lipo for hard bashing use, and 4s lipo for comp style crawling with limited bursts.
01-01-2008, 03:31 PM | #232 |
Newbie Join Date: Nov 2007 Location: Vancouver Island
Hey John, looking to order some stuff (international). Looks like your PM inbox is full.
01-02-2008, 05:28 PM | #233 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
John, Do you have the saddle packs and Axial trannies in stock? Just need to know before I order. Thanks.
01-02-2008, 05:38 PM | #234 | ||
If it is in stock on my site, I have them in stock. I know I have 6 and 8 cell saddles and I am looking at an axial tranny in stock. | ||
01-02-2008, 06:27 PM | #235 | |
01-02-2008, 06:34 PM | #236 |
01-02-2008, 09:44 PM | #237 |
Rock Crawler Join Date: Jul 2005 Location: Phoenixville
Hey john, i have the Hyperion 0606i that i purchased from you, It doesn't have any instructions but is pretty easy to use. When i charged my 3cell 2100 lipo it just automatically charged it at 2.1amps. i didn't see where i was able to change it, i'm new to lipos, i just let it charge like that and it charged in a half hour. just wanna make sure this is ok and i assume that the charger automatically sets the amps for the battery pack being charged.? |
01-02-2008, 10:05 PM | #238 | |
Yes, with a lipo it will automatically determine the charge rate. If you set it for 2100 mah it will charge at 2.1 amps max, and then taper off at the end with a constant voltage charge. | |
01-02-2008, 10:19 PM | #239 |
| Ok cool thx. i think it might have even selected 2100 automatically to.
01-03-2008, 12:09 AM | #240 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
John. I ran a veselro 2100 3s lipo tonight in my basher that has the mamba max esc and 4600 motor and when I took the battery out I noticed that it expanded and was pretty hot. Is there anything wrong with this? It was also like 20 degrees outside if that has anything to do with it.
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
