10-27-2010, 04:42 PM | #2381 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
Are you going to be stocking the new Castle SCT combo? Cheers
10-27-2010, 04:46 PM | #2382 |
I may get a few of them. What vehicle are you looking to install in?
10-27-2010, 05:57 PM | #2383 |
Probably just put the motor in my slash 4x4 or the combo in the slash:summit:axial hybrid ; although I have a rs/13.5t that might work ok on 3s. If your not getting them it's no an issue i can get from mike. |
10-27-2010, 06:18 PM | #2384 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Hi, My TorqueMaster Mini arrived this morning, unfortunately the + connector on the motor sheared within the first few mins. Any suggestions please? Cheers Mark |
10-27-2010, 06:38 PM | #2385 |
Can you use the one on the other side? On the bottom, in the lower left of your picture.
10-27-2010, 06:42 PM | #2386 |
Odd same happened to me. You can either use the other side or the little bit left. Worse case turn the motor 180 deg and resolder |
10-28-2010, 01:55 AM | #2387 |
Thanks guys, i managed to solder the wire on the little bit of tab that was left Cheers Mark |
10-28-2010, 05:09 PM | #2388 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| John, I sent you a email about if you could rebuild my "TorqueMaster Pro Handwound 30T" motor. Can you rebuild it? Last edited by justinart24; 11-04-2010 at 10:10 PM. |
11-04-2010, 06:24 AM | #2389 |
Hi guys, Was working on my MRC yesterday and found the car was locked solid, went through each section in turn and found it was the motor locking everything out. Stripped down the motor and found this. My first question is: Is there something i could have done wrong to cause this? In all honesty i did put a 3S pack on for around 5 mins yesterday afternoon, but the car ran great afterwards for 15 mins or so. Second question is: Is this repairable? Cheers Mark |
11-04-2010, 06:41 AM | #2390 | |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
11-04-2010, 10:10 PM | #2391 |
11-09-2010, 07:59 PM | #2392 |
Rock Crawler Join Date: Jul 2010 Location: St. Albans
Were is a good place to buy sping and brushes. I just got me a comm lathe and I wanna start using it and don't forget carbide cutters.
11-11-2010, 03:21 AM | #2393 | |
11-11-2010, 07:31 AM | #2394 |
Newbie Join Date: Nov 2009 Location: jakarta
| identifying a puller code
John i just got a puller from a friend. how can we tell if the sticker says " 05 cobalt 7 turns" is that mean a 500 puller or 454 puller or CP1 ? Thanks
11-11-2010, 08:51 AM | #2395 | |
That is not repairable. Was it a 22t or 33t? That is the bigger puller, the 550 size. | |
11-11-2010, 11:43 AM | #2396 |
11-11-2010, 11:44 AM | #2397 |
The 33t should actually take 3s, but every now and then we have one comm let loose. Shoot me an email and we can get you taken care of. |
11-11-2010, 02:53 PM | #2398 |
11-11-2010, 05:29 PM | #2399 |
Quarry Creeper Join Date: Feb 2009 Location: clover, sc
I have the pro hand wound 45t. I have had them for about 8 months. Everything was fine until the front motor just stopped working. It will work then stop. I checked the comm, looks fine. The brushes are worn down a little but not chipped or broke. I cleaned it up and put it back together and nothing. I can spin the comm and it will run but I can stop it. What can be the problem? Thanks. Bryan |
11-11-2010, 06:47 PM | #2400 |
Could be a bad segment, or a comm gap that is too wide. Have you given it a comm cut yet?
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
