09-15-2011, 01:48 PM | #3021 |
Pebble Pounder Join Date: Sep 2011 Location: Bend
| 13T and 55T
HH, I'm just getting into crawling and doing it with the Wraith. I just ordered a Crawlmaster 13t Team 2012 Edition and a Torquemaster 540 55t. I probably should of asked more before ordering. Anyway I figured that got me the far ends of the spectrum and the chance to experience the difference. What is the difference between the Team 2012 Edition and the regular Crawlmaster 13t? I also ordered a 2S and a 3S batter along with your BRXL ESC. What gearing should I use with the 13t for crawling? What should I be looking at for the 55t for speed and bashing around? I've done a lot of reading, need to do lots more looking forward to my package from you. Oh - also I got the ESC water proofed, any concerns with water and the brushed motors (besides longevity) ? |
09-15-2011, 02:04 PM | #3022 | |||
If you get the motors in water, just be sure to clean them out after each run so they don't rust. I think you made some great selections to get you started! | |||
09-17-2011, 10:13 PM | #3023 |
Newbie Join Date: May 2011 Location: Mt. Vernon
HH just got one of your 28 turn crawlmaster motors for my wraith and like the torque its putting out. My only problem is on 2s with stock gears its really lacking for wheel speed. would you recomend trying to gear it higher or switch to either 3s or 4s to gain back a little wheel speed?
09-18-2011, 08:49 AM | #3024 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
Hi John, Just want to get an update on this order #7450. Thanks |
09-18-2011, 11:28 PM | #3025 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
I just purchased a Crawlmaster Pro 13t from one of our lhs. I put it in one of my scalers, which weighs 9.5lbs with 87spur and 15t pinion. I ran one 3c 4400 pack through it today. I really like the motor, my question is why the motor got so hot? I'm worried if I keep running it, I will burn it up. Should I put it in my Wraith instead and get something else for this heavy rig? Maybe one of your pullers would be a better choice? Here is a pic of the rig: [IMG][/IMG] Thanks. |
09-20-2011, 07:54 AM | #3026 | ||
We should have some 20t arms done in the next few days to complete your order, thanks for being patient while we are moving the business! Quote:
09-20-2011, 07:55 AM | #3027 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
BTW, Congrads on the marriage John. |
09-21-2011, 12:19 PM | #3028 |
Pebble Pounder Join Date: May 2010 Location: Ephriam, Utah
| Help
First and for most congrats on marriage. I am going to be building a wraith for the wife. I have been looking at your gear. I currently use A tekin fxr set up in my Honcho. She wants alot of speed. (which is a good thing ) I wold like to run 3s lipo. 1300 MaH. I do have a tekin Hotwire, could I get the FXR and use on of your motors, Should I get a Bec? (i dont run on on Honcho, SHould I?) If I do run a BEC could I use extension line and take red wire out of that instead of taking it out of esc connector? (what to still use hotwire) How High turn of motor can I get with using 3s lipo? if I use a 25t can I still use 3s or is 2s better? Sorry for all the ?'s. I just want to do what is right. thank for the help. |
09-21-2011, 02:09 PM | #3029 |
Quarry Creeper Join Date: Dec 2008 Location: La Costa, CA
Couple of quick questions. I just recieved your TorqueMaster Pro 35T I won from TCS Does it come with 0 timing? Do I need to change that? Its going in a 6.3lb SCX10. Last question, you reccomended a 15T pinion for good crawling so I picked one up, its a Robinsons Racing 48 pitch. Is this the right pitch? Thanks
09-23-2011, 07:55 AM | #3030 |
Newbie Join Date: Sep 2009 Location: pittsburg
Hey john I picked up one of ur waterproff speed controlers and it dose not look like my buddys its like the one I have did u change the epoxy look thanks .beau |
09-23-2011, 01:55 PM | #3031 | |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
John, I am wanting a new motor for my SCX10. Right now I run the axial 27t because I got them cheap. I really want something with about 25-50% more wheel speed and definitely more torque. This is running 3s on your BRXL controller. | |
09-23-2011, 03:16 PM | #3032 | |
I would strongly consider running the 16 turn on 3s (or even 4 really) with taller gearing. The 1.9 tires will put less of a load on the motor, the 5 slots will still have killer low speed control, and gearing her up will get you the speed you need. I would try 18 tooth pinion, 87 tooth spur, and a 16 crawlmaster. Maybe even a 13 with that setup, but it will get hot a little sooner than the 16, so if you like longer trail runs then you may want the 16. Also the crawlmasters are super low amp draw and your same packs will last longer than with that axial sealed can. | |
09-25-2011, 03:27 PM | #3033 |
Pebble Pounder Join Date: Aug 2010 Location: Arvada
I installed a waterproof BR-Xl along with a crawlmaster 13t in my Wraith. I am mostly running it on 3s but occasionally 4s. I took it out today and started with a 1000mah 4s... ran until lipo cut and stuck a 2200 3s in it. Less than 15 minutes into the run it starting getting really weak then just shut off all throttle control, steering and lights were fine(running off a CCBEC). I disconnected the battery and plugged it back in. The speed control made no sounds at all. I thought it may have hit some kind of thermal shut down(was not hot at all though) so I left the battery disconnected for well over an hour. When I tried it again later it beeped just fine and started going but it was very weak then it shut off and wouldn't do anything again. I tried just a minute ago with a 4s and it beeped very quietly and scratchy and started working very slowly and stopped again. Is the speed control fried?? If it were a rx or tx issue the speed control would still beep for lipo but it would never arm correctly...I am getting no beeps so it sounds to me like the speed control. I just bought it a couple weeks ago at my awesome LHS.
09-25-2011, 11:14 PM | #3034 |
Quarry Creeper Join Date: Nov 2008 Location: The Darkside is strong with this one!
| BR-XL problem
Hello, I have a newer BR-XL that I tried to hook up for the first time tonight. All I get is a slow red LED flash. No beeps or anything else. I have checked all of my connection and everything looks fine. When I setup the other one it works great (front esc). When I hook the two up to the reciever the other one (front) starts to work intermittenly. I was trying to set them by themselves, not wired together. Useing in a dual esc setup with 16T Crawlmasters. Thanks Chad |
09-26-2011, 08:52 AM | #3035 | ||||||
716 W. Sexton rd. Columbia, MO 65203 Quote:
09-26-2011, 08:59 AM | #3036 |
OK I will try to reflash it. Thanks for the fast responce, Chad Last edited by Psychomonkey RC; 09-26-2011 at 12:04 PM. |
09-26-2011, 11:28 AM | #3037 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
ok johnrob, i have two 7t pullers sitting here, two mamba max ESC's both in brushed mode with auto lipo and usb ports that don't work any more. i did some looking and the two speed old emaxx transmission seems to have about the same gear ratios as the transmission in my old savage. a 7t on 3s will spin, in theory about 30krpm which will be fairly close to a nitro motor top end. if i do a savage electric conversion, will the two puller's do the trick? the sucker weighs like 15lbs right now. is dual ESC and dual battery the way to go? i know your site lists the 7t amperage at 38 and a MM puts out 100. I also seem to have one of your BR-XL waterproof ESC's laying around. any thoughts on this idea? tim |
09-26-2011, 12:03 PM | #3038 | |
Tried to reflash it and still a no go. Do you want me to try anything else or just send it in? Thanks Chad Last edited by badger; 06-21-2012 at 11:34 AM. Reason: address change | |
09-26-2011, 12:49 PM | #3039 |
| okay thank you very much will order Bec soon and an extension... Thank you for your support of the site and being a great vendor
09-26-2011, 02:05 PM | #3040 |
Quarry Creeper Join Date: Apr 2011 Location: Mt Vernon
I pre-ordered a Wraith kit so I'm needing a motor. I got a BR-XL from you when they were on sale and I'll be running a 3s lipo, maybe a 4s. What motor would you suggest? I'll be doing some crawling/bashing like most others here. I would also like some nice wheel speed when I need it. What motor do you sell the most of for the Wraith? Thanks, Eric |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
