01-20-2008, 10:29 PM | #321 |
I am working on finding some Castle links. Castle is out, my supplier is out, I am ringing the bottom of the barrel trying to find some ATM. The sidewinders will need them.
01-21-2008, 08:47 AM | #322 |
Rock Stacker Join Date: Dec 2006 Location: Saratoga, NY
Severe newb questions, but I want to get my order right. I have an E-maxx and I'm running the EVX at 14.4V and both stock Titan motors. Everything is stock for the connections, plugs, etc. I'm also using the stock RX. I want to to order a CC BEC @ 6.0V now that I've picked a higher torque servo for the front and I've added a high torque servo for rear steer. Connector option: Should I choose a Deans? What other bits and bobs do I need to get this wired up to my batteries/ESC/Rx? I assume I'll need to splice in a connector from the battery/esc. I hate placing multiple orders because I missed out getting one small piece. Thanks for the help. |
01-21-2008, 10:10 AM | #323 |
If you use a deans plug, you will need to convert all of your batteries, ESC's, and chargers to deans as well. The other option is to solder it onto the power wires of your ESC, just tap right behind the battery plug. The BEC can just plug into an extra channel on your RX, or you can use a Y harness to route power direct to the servo and RX at the same time. There isn't anything else needed. |
01-21-2008, 10:19 AM | #324 | |
01-22-2008, 09:30 AM | #325 |
Rock Stacker Join Date: Nov 2006 Location: York, PA
Hey John, Are there any brushless ESC's out there that can run two motors, like the Novak Rooster? |
01-22-2008, 10:15 AM | #326 |
Not that I am aware of. You will need two motor controllers for two brushless motors.
01-22-2008, 11:05 AM | #327 |
That's what I have. I actually bought a pair of Hyperion z3013's and Mamba 25's from you early last year. Due to various reasons I hads to step away for awhile. I was just curious if anything new had come along since then.
01-22-2008, 09:43 PM | #328 |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
Any idea on stock updates for the 10t colbalt puller and a Mamba Max?
01-23-2008, 08:27 PM | #329 |
Quarry Creeper Join Date: Jul 2006 Location: Salem
Any word on when the site will have a sidewinder, CCBEC, and puller motor combo? Also any word on restock of the Castle Link?
01-23-2008, 09:22 PM | #330 | ||
Castle links are on the way, probably tomorrow or friday. | ||
01-24-2008, 12:16 AM | #331 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
John, I have some non-crawler electronics questions for you. As you probably know, your PM box is full again. On my e-revo, I have the following setup: schulze 18.97kw li-saver (since the schulze doesn't have a low voltage cutoff) TrueRC 5000mAh 18.5 5s1p pack Feigao 8xl purple can motor It works just fine with out the lipo cutoff. It wheelies uncontrollably, but when I plug it in it saps all the speed and if I punch it, it starts cogging, like it is kicking in the voltage cutoff. If I slowly build up the speed, it will get to speed and not cog. Is the problem that this battery just isn't powerful enough to give it the amps it needs or is that cutoff circuit just too touchy for that esc? Are there any other escs out there that will handle the 5s? I was looking at the MGM Compro 160amp in specific. I'm thinking I'm going to have the same problem with that one if it is the battery that just doesn't have enough power. Any suggestions? |
01-24-2008, 07:43 AM | #332 |
Pebble Pounder Join Date: Dec 2005 Location: MODESTO
Ultimate 2.2 Comp Combo **on Sale** #181 when you gonna get more in ? |
01-24-2008, 10:20 AM | #333 |
John, I plan ordering 2100 lipo on your site and the LBA 10 Balancing Aadapter Thunder Power/ Flightpower, Do I need anything else to get the balancer to work with my ice charger as far going from the charger to balancer?
01-24-2008, 10:32 AM | #334 |
| PM Box is full so I will post it here. I'm sure everyone can benefit from his answers. I'm currently running a wheelie king with a full crawler conversion, and I'm looking to get an Axial. I know a few things for sure. The axles will be Axial, the chassis is going to be either Benders or the Blackjack, transmission will be R2D with the dig and I know I want brushless/lipo combo. What do you recommend for the electronics? Speed controller: Motor: Voltage reg: Battery: Servo's: I'm trying to get as many parts from 1 vendor as possible, so I can keep track of everything better as I build my comp crawler. Thanks for the help man! Chris |
01-24-2008, 06:42 PM | #335 |
Newbie Join Date: Nov 2007 Location: Vancouver Island
Hey John, Parcel arrived yesterday. Everything looks great, thanks for the stickers. Amusingly it arrived in Canada on the night of the 11th. It just took THAT long to get through customs. Thanks |
01-24-2008, 06:47 PM | #336 |
Newbie Join Date: Jan 2008 Location: houston
Hey JRH, Building my first rock crawler rig, I'm going super class / hustler. I,m wondering if the crawlmaster/ mamba max combo is a good motor and esc to run for the build? I going 4whl steering for sure. I,m also not sure about what battery to run with the combo also? First time on the thread, really glad to find the help. THANKS |
01-24-2008, 10:14 PM | #337 | ||||||
Speed controller: Sidewinder Motor: 55t, revolver, or crawlmaster Voltage reg: CC BEC Battery: 8 cell 1500 saddle or 3 cell 1300 lipo (or bigger) Servo's: hitec 5995 or 5955. lowballer choice is 645mg or waypoint 1630MG (good for dig too with a spring on the engage side) Quote:
01-24-2008, 11:41 PM | #338 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Can the mamba maxx handle a 4 cell E-Moli Li-Ion battery? They're the cells out of the Milwaukee V28 packs (same type of cells as the a123's), but they are 4.0 volt cells and 2800mah. Also, can the 5idp ac/dc properly charge it if I set it to a123 16.5v pack mode? |
01-25-2008, 12:07 AM | #339 |
4s emoli would be pushing it pretty hard. A high turn motor like a 55 or 65t lathe would be a safe bet if any will work. You will certainly need an external BEC. 16.5v a123 should give a good charge to the emoli. I don't know the particulars of cutoff, but I know they are pretty stout cells like the a123. |
01-25-2008, 12:15 AM | #340 | |
What about 4 cell a123's? I would like to run them on my scaler (35t) and my super (2x 55t's). How about charging a 3 cell emoli on the 5i? It's kinda right in between the a123 options. Also, cc bec will be run on everything. | |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
