01-15-2013, 12:31 PM | #3461 |
Newbie Join Date: Dec 2012 Location: Smithton
No I've only drove it inside my house right now. Hasn't even been through 1 full battery pack. I just purchased your brxl and 27t rock racer motor a couple weeks ago and have been building it and trying to get it the way I want it.
01-15-2013, 01:44 PM | #3462 |
| Re: (HH) Tech Questions and Customer support thread
Did you specify wraith timing or set the timing for clockwise direction? If it was not timed properly it will burn the comm. Otherwise there may be something in the motor causing the hangup.
01-15-2013, 02:02 PM | #3463 |
I never timed anything. All I did was install the motor and esc and have been driving it around. It has 32p 56/12 gearing in it. I was under the impression that it came set. I bought a castle link field card but I have not hooked it up to it yet |
01-15-2013, 02:25 PM | #3464 |
Motors come with zero timing if you purchase them from another vendor, or if you purchase from myself without specifying the timing or vehicle. Since many vehicles use different rotations for "forward" there isn't a standard we can lean on. Zero timing is safe, but not optimal. There is a tech tab at the top of my site with a writeup on timing brushed motors. You may just have a hung brush, hard to say without looking at it myself.
01-15-2013, 03:48 PM | #3465 |
Hmm alright. What do you suggest I do with it? I just tried driving it around my basement and it won't even climb up the stairs now and before it did it easily. It seems to make some odd noises now. And it will periodically just stop going while driving it. It's in a wraith. Should I adjust the timing now with the field link card and see if that helps?
01-15-2013, 07:23 PM | #3466 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
I also posted this in the BRXL thread...here too since the OG issue started in this one I think... Ok, here's a weird one. This is the same BRXL I bought new not too long ago that always had some resistance when trying to spin the tires by hand with the battery disconnected, but would free up when a motor wire was disconnected. John thought maybe an FET or whatever might be going bad. I didn't sweat it since it worked fine otherwise. Sunday it started acting weird as soon as I plugged in my battery, it took more than half throttle to get going, and didn't seem like it was getting full throttle. Then it started not moving at all until I gave it a push, so pulled the brushes and made sure they were clean and not hung up. Swapped batteries and it ran like it always does. Maybe half hour later same thing, so I thought my batteries dumped early. Today I plugged it in and the steering turns left when powered on and flashes red and beeps continuously with no throttle or steering. I did a rebind on the tx ro rx and tries to recalibrate the ESC to the tx but it won't even do that, just flashes red and beeps continuously. Any ideas? I'll email John this post and see if it needs a trip back for a treatment with his big hammer. |
01-16-2013, 11:08 AM | #3467 |
Pulled the motor out and it has a lot of black dust on it. I'm gonna time it now. I also remembered when I installed it. I had to select reverse in my controller under throttle selection because it went forward in reverse and vice versa.
01-16-2013, 02:30 PM | #3468 |
Pulled the motor apart. When u spin the pinion it seems to spin in notches. It doesn't spin freely and smooth. It seems to me like its rough.
01-16-2013, 04:51 PM | #3469 | |
| Re: (HH) Tech Questions and Customer support thread Quote:
01-17-2013, 07:20 AM | #3470 | ||
Take some pics of it, refresh me on what is going on, and send an email to jrh at holmeshobbies.com. From there I can help out a bit better. Glad to hear that helped out. Sometimes things get a bit whacky and they just need a firmware refresh to get back to normal. | ||
01-17-2013, 10:20 AM | #3471 |
Well John as of right now it's running fine. I took it apart and timed it. Should be right about 6 degrees and made some adjustments via castle link and its running good. I turned Holmes hold on and it made the motor make some strange noises. So I turned it back off and it's been good for now. Thanks for the support!!
01-18-2013, 10:30 PM | #3472 |
Quarry Creeper Join Date: Sep 2008 Location: NW San Antonio
What is the correct polarity for plugging a BRXL into a receiver? Does brown equal black and orange equal yellow? Thanks, Jon D. |
01-19-2013, 12:12 AM | #3473 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
The darkest color is the negative.
01-21-2013, 07:33 AM | #3474 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Hi John, I sent you an email on the 14th and have seen no reply. Just checking you got it?? |
01-21-2013, 10:00 AM | #3475 | ||
I'll look through when I get to the shop tomorrow, thanks for the heads up! | ||
01-25-2013, 10:26 PM | #3476 |
Rock Stacker Join Date: May 2010 Location: tx
Hello John, I have a torquemaster expert 45t, I have had maybe 3 packs through at 1 hour and 1/2 each, on my forth pack it seems to have lost power and stalls out, it would get warm during crawling but not hot, now its get super hot pretty much untouchable. I have cleaned it and cut the comm and the brushes but didn't seem to help.. my specs are ae-2 and castle bec, 15t pinion 87 spur, 2.2 tsl in a 8lb Wraith. 5000 nimh venom 7.2v.. Thanks
01-26-2013, 07:47 AM | #3477 |
Could be a damaged coil, or the magnets got overheated and now they need zapping. If you want to send it in we can certainly take a look!
02-04-2013, 12:29 PM | #3478 | ||
Quarry Creeper Join Date: May 2012 Location: Italy
02-04-2013, 05:50 PM | #3479 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
ok I just got a HH Expert 35T. Now I see I have to break it in 2-3 volt run 2-3 minutes at 6 deg advanced timing. I see the timing marks now how do I move it? Just loosen up the two screws on top and rotate it?. I did read the 540 Brushed Motor Care, Installation, and Troubleshoot guide but I just want to make sure I'm doing it correct. I rotate the timing 6 deg in the opposite dirrect of forward correct? I'm putting it in my SCX10 with Stock Axial ESC w/ CC BEC |
02-04-2013, 07:59 PM | #3480 | ||
The expert is broken in and ready to go Quote:
Thanks for the order! | ||
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
