05-12-2008, 05:31 PM | #821 |
05-13-2008, 08:41 AM | #822 |
Rock Stacker Join Date: Feb 2006 Location: Grand Junction
05-13-2008, 09:40 AM | #823 |
The crawlmaster is a little stronger |
05-13-2008, 12:46 PM | #824 |
05-13-2008, 03:34 PM | #825 |
No, but I think you are referring to max charge per cell, not nominal running voltage.
05-13-2008, 05:13 PM | #826 |
05-13-2008, 06:03 PM | #827 |
a123 is 3.3v/cell nominal. Depending on the charger they can "peak" from 3.6 to to 4.2v/cell. 3.8v/cell is a standard charge to push them a bit hard, chargers with a123 mode cutoff at 3.6v/cell. They can take upwards of 4.2v each before they start to blow, but even at this high voltage the cells can be cycled again and again with little capacity loss. I accidentally charged mine to 4.2v/cell once. Didn't hurt them from what I can tell.
05-13-2008, 06:17 PM | #828 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I think the Devil is refering the the milawaukee cells we are running there nominal voltage is somewhere around 4.5 and the running voltage should be 4. But they are technically a a123 right? The same copmposition of cell, right? |
05-13-2008, 06:37 PM | #829 |
They are not the same. Milwaulkee cells are lithium manganese. a123 is lithium nano-phosephate.
05-13-2008, 06:41 PM | #830 |
05-13-2008, 06:44 PM | #831 |
05-13-2008, 06:52 PM | #832 |
05-13-2008, 09:02 PM | #833 |
Newbie Join Date: Apr 2008 Location: Chicago
| How do I make a License Plate
Does anybody have a cool way of making license plates.And I may know but do i print out a picture of one that i really like.And how do I make sure that it is 1/12 scale.
05-13-2008, 09:07 PM | #834 |
Your asking the wrong guy. I would measure a plate in inches, divide by 12 for the scale size, and just print a few out on my printer and put it under tape. I'm more of an electronics type of guy, not so much a scale guru. |
05-14-2008, 08:46 AM | #835 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
How does your handwound 35t compare to the 35t Warrior?
05-14-2008, 10:31 AM | #836 |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
Would you recommend a HHH for a go-fast clod? Which one? I want wheelspeed for huge roosts with Maxx-size Paddles and torque to break traction on dirt with HPI Dirt Claws. I'd really love to run 12 cells just for bragging rights. Heavy go-fast clod, 1/6 tuber.. maybe I'm asking too much? |
05-15-2008, 08:06 PM | #837 | |
| They are very similar, but mine use a two magnet can instead of a 4 magnet. It makes a bit more torque at a small sacrifice to speed. Otherwise they are built with the same parts, and probably by the same winders. Quote:
Hmmm, maybe a 21t or 17t? I have never set up a clod for really fast running so I am in the dark on that one. | |
05-15-2008, 10:32 PM | #838 |
Rock Crawler Join Date: Apr 2006 Location: I hope you SHUT UP!!!
JRH- I am looking to cut weight in my 2.2 rig and want to go from a 35t warrior to an extremely light and small in size bl setup. which BL motor do you recommend? I also want it to be as smooth as possible. with that being said how much lighter would we be talking if you happen to know? also I am running a 2cell lipo if that helps in making a decision thanks! Last edited by Mac10; 05-15-2008 at 10:35 PM. |
05-16-2008, 07:13 AM | #839 |
You will drop about 2.5 ounces going to a revolver. You will drop almost 4 ounces going to a 2215 sized outrunner. On 2 cell lipo you will really have to watch the gearing, as it will be easy to overgear and get stalling issues. An outrunner wont be as smooth as a brushed motor either- no way around that.
05-16-2008, 08:25 AM | #840 | |
I see the 17t has a ~3700kv rating, will it take 12cells? That's 2 6-cell packs in series, 2 17turns in parallel. On 14.4v and stock gearing in a clod axle with maxx wheels, that should be ~45kmh, that's 28mph. The 21t should do 22mph... Do you carry any ESCs that can handle my setup? I'm thinking MM, but I don't know if it can handle 2 17ts or 21ts in parallel. Heatsinks on the motors, btw... | |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
