Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: (HH) Tech Questions and Customer support thread
Closed Thread
Old 06-20-2008, 05:39 PM   #941
hello recently i bought 2 of your crawlmaster motors one 850kv crawlmaster and one 1000kv crawlmaster sport, i installed the 850kv on my ax10 rtr with a mamba max esc and a cc bec. after i installed it i tested it and it sqeals and has no power any time i put it under load it just squeals and lugs like power is on and off. i was wondering what if any advice you could give me.:-(
27cameron is offline
Old 06-20-2008, 06:59 PM   #942
jrh looking to mount a 7t puller to an rc4wd 2 speed ... need the motor plate so i dont have to drill out the tranny could not find it on your site .... what pinion do u suggest ... 3s lipo . sidewinder . thanks
rockwood330 is offline
Old 06-21-2008, 09:18 AM   #943
Default Gell batt ?
JR .. A lil crawler OT, but I can't find an answer. I have a 12V 7 amp gel for a starter box. My auto charger has a gel, 2 amp mode. Will I kill the batt with this ? TIA
nomobux is offline
Old 06-21-2008, 11:38 AM   #944
Keep it real
Tanis's Avatar
Sounds like you have the mamba set to Brushed mode.
Tanis is offline
Old 06-21-2008, 06:55 PM   #945
john, somewheres i heard you had a pdf schematic for the microswitch dig setup for the berg crawlers. i figured it out(killing power to one motor) but i wanted the printout if its located here anywhere? thanx
TREE68 is offline
Old 06-22-2008, 09:00 AM   #946
hi john,
i got hyperion eos0606i(DC only) today. i did read the manual, but not use my charger yet. there is a charge, discarge and cycle mode in nicd/nimh modes. when i use this cycle mode? use it on all batteries or just batteries that not use for long time?
then, i had lipo battery 11.1v 1800mah with no balancer connector, is it save charging without balancer connector?
thank's
deephis46 is offline
Old 06-23-2008, 01:24 PM   #947
Default Outrunner Motor Plate
John,
I have a Revolver Outrunner, AX-10 (purchased from you), do I need the Axial Outrunner motor plate or will the stock one work. I checked the motor against the plate supplied with the kit and the holes line up but I don't know if there is some other reason for needing the other motor plate.
Thnx
HaSharetz is offline
Old 06-24-2008, 02:39 PM   #948
Tire&Foam Extraordinaire
Nova's Ark's Avatar
JRH, when will you have more Side Winders in stock? I would like to order a Side Winder and BEC from you.
Nova's Ark is offline
Old 06-25-2008, 09:01 AM   #949
cartronicshn's Avatar
Hi Johnrob, i need a couple more castle voltage regulators i forgot to include in the order, any chance you put it the same shipment? pm the total for 2 of the voltage regulators.
Thanks,
Carlos
cartronicshn is offline
Old 06-25-2008, 11:48 AM   #950
Default 7t puller
ive got a question? my puller just started arcing real bad at the brushes. it ran fine at the last comp then i went to turn it on to run today and it started. any idea on the cause?
mental is offline
Old 06-26-2008, 10:03 AM   #951
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Originally Posted by CD13 View Post
When you gonna get the Mamba Maxs in stock? I need a couple of things and I want to order them all a the same time,Mamba Max,Bec and a servo.
Waiting on the next production run, should be 3 or 4 weeks.
Originally Posted by harleyboy61 View Post
battery i just received it yesterday i wanted to know what rate i should charge it at i ordered the 8.4v saddle pack . also i want to eventually get your cobalt puller 7t i have a tazer 15t will this esc work when i finally get 7t?
For future reference 1.5a is the max recommended rate. I have added it to the product page for all future orders.
Either the ESC is on brushed mode like Tanis suggested, or you need some better batteries. What batteries are you using?
You don't need the motor plate, the PUller will bolt right up.
That is quite high for a lead acid. I would recommend under 1 amp. You don't want to charge much faster than 1/6 of the capacity, ss just a hair over 1 amp would be the max.
Thats not me, poke around in the berg section for it.
Originally Posted by deephis46 View Post
hi john,
thank's
Cycling batteries is useful for packs that have lost capacity. It can also bring them back into balance for nimh. You can charge a lipo with no balance connector, it just might not last as long as a pack with a balancer.
Originally Posted by HaSharetz View Post
John,
Thnx
Nope, the Revolver bolts right up so you won't need anything different than stock.
Waiting on them now, should get a shipment within a few days.
Thanks,
Carlos
Can do, just send $36 to my paypal addy.
Arcing would be caused by the timing being negative. Check the endbell and see if it is loose. You may need to retime it.
JohnRobHolmes is offline
Old 06-27-2008, 07:17 AM   #952
Done, and thanks, lmk when it ships.
Thanks.
Old 06-27-2008, 08:52 AM   #953
NOOB Question. I would like to upgrade my battery pack not sure which way to go? 2cell 7.4 1300mah lipo or 6/8 cell saddle packs 1500mah. Would the lipo have more punch or longer run times?
Thanks for your help 65t motor sidewinder esc
Torch is offline
Old 06-27-2008, 09:11 AM   #954
The lipo would have less runtime but more punch. It would keep a higher voltage under load as compared to the 6 cell pack. I would choose an 8 cell nimh over a lipo unless you have space to mount the two cell on your axle.
Old 06-27-2008, 09:18 AM   #955
I was thinking about mounting to the front axle. Do you offer a higher mah in the smaller size lipo.
Torch is offline
Old 06-27-2008, 09:28 AM   #956
not at the moment. You could run two in parallel and stack them. Otherwise any more MAH means a longer cell right now. I am working on something with more mah, but it will take a while.
Old 06-27-2008, 11:00 AM   #957
Arcing would be caused by the timing being negative. Check the endbell and see if it is loose. You may need to retime it.[/quote]
how do i retime it?
mental is offline
Old 06-27-2008, 11:06 AM   #958
I will probably need to take pics if you are not familiar with the procedure. Basically the brushes need to be right between the magnets if you look down the motor.
Old 06-27-2008, 11:11 AM   #959
Pictures would be a lot of help since im kinda oblivous to how to do it.
mental is offline
Old 06-27-2008, 11:15 AM   #960
Will do, I will message you with the thread/ link when I get it done. Probably this evening, I know you want to get running as fast as possible.
Closed Thread
(HH) Tech Questions and Customer support thread - Similar Threads
Futaba customer support XJkid93 Chit Chat 6 07-24-2012 06:07 PM
ZNO-RC Customer Support ZNO-RC Redcat Crawlers 28 03-20-2012 08:44 PM
axial customer support/service THANKS! superflex General Crawlers 6 01-31-2011 08:40 PM
airtronics customer support dlamb11877sf Electronics 0 04-13-2010 10:04 AM
You may edit your posts
