11-16-2007, 01:59 PM | #81 |
3mv per cell for small ones.
11-16-2007, 02:39 PM | #82 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
11-16-2007, 02:47 PM | #83 |
That might not be changeable on the 5i, I can't find it either. Don't worry about it then.
11-16-2007, 03:16 PM | #84 |
11-17-2007, 04:14 PM | #85 |
DOOH!!! Join Date: Feb 2007 Location: AZ
Hey John, Got a couple of questions for you, First is on a dual Mamba Max setup with a CC BEC, i have the red wires pulled from the MMs and the BEC is set up on a switch. When i turn the BEC off the lights on the MMs stay on, very dim but still on. Does the MM hold some residual power that's still running the leds? if so then would it be ok to bypass the MM switches so i only have one to turn on? Next, Would it also be ok to bypass the switch on a Mamba 25? Thanks in advance! |
11-17-2007, 06:30 PM | #86 |
With a mamba max, you will have to have them turned on for them to function. Keep the switches turned on (or hardwired) and pull the red wires. If the MM is still plugged into the battery even with the switch off they pull some current. I just use my battery plug to turn the rig on and off. I hack the switches off of my mamba 25's and solder the wires together. Plug in = ON. |
11-18-2007, 12:20 PM | #87 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Hey John, I have a Mamba Max, Crawlmaster, Hitec HS5955TG Servo and 9cell 1500 Elite Pack All Brand New!! When I try to power up the system after setting up the Mamba Max, I get good power to the servo but nothing @ the MM, no lights no power nada. The MM seems to get a little warm not hot within just a few seconds. Any Suggestions? |
11-18-2007, 01:20 PM | #88 |
Are you are using an external BEC?
11-18-2007, 01:27 PM | #89 |
Not yet, in fact I sent you an email asking if I needed one and whether or not I needed a BEC or Regulator
11-18-2007, 01:32 PM | #90 |
It sounds like the ESC doesn't see your radio signal, but it should be blinking all of the lights. The BEC is working but the control board isn't turning on. Give castle a call on this, it sounds like warrenty.
11-18-2007, 01:38 PM | #91 |
Thanx John, Thats what I figured. I was also thinking I might order another from you to get me going faster, And when the warrantied one comes in, sell it. How long does it usually take Castle to Warranty or repair? |
11-18-2007, 01:41 PM | #92 |
It depends on the situation and how much stock they have. They should have controllers on monday still, give them a ring and leave a message if needed.
11-18-2007, 01:46 PM | #93 |
Thank you again John. So with my described setup do think I need a BEC or regulator?
11-18-2007, 04:23 PM | #94 |
I would say yes, the 9 cell pack will make your internal BEC weak.
11-19-2007, 06:12 PM | #95 |
Hey John, If I order the Mamba Max tonight and pay for Express Mail Will it be to me before Thursday??
11-19-2007, 06:18 PM | #96 |
It should. You should get it on wednesday unless something screwy happens. Of course mail doesn't run thursday.
11-19-2007, 06:22 PM | #97 |
Yep, that's why I ned it by thursday, I would have ordered it first thing this morning but my wife needed some "nudging" Payment on the way and could you please be sure this happens on your end??? Thank you again for your great work John!!! BTW, After Castle running me thru some testing the new MM I have is DOA!! Shoulda bought it from you in the first place! Is the mail running friday? |
11-19-2007, 06:29 PM | #98 |
Thank you John Payment Sent, Would You Please Let Me Know When this Has Been Shipped!!???
11-19-2007, 10:12 PM | #99 |
It will go out tomorrow, you will receive a confirmation email.
11-21-2007, 05:55 PM | #100 |
GREAT JOB JOHN!!! It Arrived today!!!!!! If there is any question about John Holmes service, I will banish the unfaithful!!!!
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
