07-31-2008, 06:26 PM | #1001 |
Quarry Creeper Join Date: Apr 2008 Location: Alexandria
John Robert, A lot of people are running the puller motor in the edge chassis and it is fitting well. I'm almost sure the motor sits inside the chassis as well. Also, the warthog chassis by hardbodyz seems to work, there is a build thread on ehre where a guy has one installed, it's a big chassis anyway. Also, a lot of guys are running them in the blackjack builds, but you do have to trim the chassis for that.
08-02-2008, 02:45 PM | #1002 |
Hey John, I just tried to order a few 35 turn handwound motors, but it only showed one in stock. Do you have some in stock that aren't on the website or is that it for now? If you do have some, I need another one. |
08-03-2008, 08:14 PM | #1003 |
Rock Stacker Join Date: Dec 2007 Location: in the "D"
| berg
ive got a super rooster crawler esc and i m getting a berg soon. what do you reccomend motor wise and also should i get a bec???
08-04-2008, 08:34 AM | #1004 |
Rock Crawler Join Date: May 2007 Location: Glendora
| Building a Motor???
I was going to use a Reedy (12x2) Ti modified motor can and insert a 55 turn armature...any thoughts on performance, durability, or if it would even work? I am figuring that the upgraded can with ball bearings would help the motor be more efficient and produce an increase in run time...??? Thanks |
08-09-2008, 08:45 PM | #1005 |
RCC Addict Join Date: Feb 2006 Location: ccxc
When will we see cobalt brushes in stock?
08-12-2008, 04:57 PM | #1006 |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
Mr. JRH, when are you gonna have more Hyperion chargers in stock? Looking for the 606i ac/dc.
08-13-2008, 07:38 AM | #1007 | |||
For a motor a 55t through a 35t can't do you wrong. Quote:
Still working on the quote from the factory. I will have to buy 3,000 of them Still working on it though, rest assured. If you manage to wear through your brushes give me a call and I will take some out of my personal stash of motors to keep you running. Just got notice they are shipping to me now. Hyperion was very backed up on the 0606i ac/dc. | |||
08-16-2008, 01:26 PM | #1008 |
Quarry Creeper Join Date: Jul 2006 Location: Apple Valley, CA
Hey John! This maybe a repeat question. I just picked up another CC BEC, and was wondering what kinda voltage are the Towerpro 995's happy at? I'm running 2 on a Super, with 3s lipo! Thanks in advance!!....
08-16-2008, 03:36 PM | #1009 |
I have used them on 7.4v, but they heat up. For a few minutes at a comp you can push them, just dont let the case hit 140f. Normally 6v |
08-17-2008, 07:34 AM | #1010 |
| I'm running these exact servos at 6 volts with a Castle BEC and they've been quite happy so far. I've been testing prototypes so I'm abusing them way harder than normal, and they are just barely feeling warm to the touch when I get done. Of course I do have my endpoints set so as not to overstress the servo. A friend of mine doesn't have endpoint adjustment, and his towerpro was getting hot at 6 volts, so he adjusted his driving style and hasn't had another problem.
08-17-2008, 09:33 AM | #1011 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
hi...i don't know if anyone has asked same question...but do you have any thread that discuss about Castle Creations software or firmware update?
08-17-2008, 09:57 AM | #1012 |
I don't. Not enough details for a thread really. What can I do for you? Have your read the FAQs on Castle's site?
08-17-2008, 07:05 PM | #1013 | |
luckily i have backup from previous version v3.04...then i uninstall v3.11 back to v3.04 and have great result like before. i got problem too with the firmware update for sidewinder. i only got v1.16 and v1.17. which is the newer version is v1.18. do you ever have problem like that? how can i get previous version? do you always update all castle products or not? i have read on castle's site, but i didn't get clue for my problem. | |
08-17-2008, 07:51 PM | #1014 |
Newbie Join Date: Aug 2008 Location: Graham
| Moving Link question
My fiance has an axial AX 10 scorpion and he has purchased an aftermarket plate ( I think it is a servo plate). In order to use this plate effectively he needs to move the links to the inside. Can someone tell me how this can be done or is the a link that goes to a step by step on doing so. A gentleman at the hobbie store said there was a step by step on rccrawler.com/techsupport, bt I have been looking for over 2 hours and have found nothing. Any help or advice will be greatly appreciated. Thanks |
08-17-2008, 08:07 PM | #1015 |
Pebble Pounder Join Date: Aug 2008 Location: Marysville
With a berg or clod, and high turn brushed motors, does the freewheel setting on a Dig really do you much good? Doesnt seem too... Is it better with brushless motors? In other words, is there less spinning resistance on a brushless motor that is not powered? |
08-17-2008, 08:26 PM | #1016 |
John got a weird one for ya... mm been working perfectly since I bought it almost year ago. Pull out of my old comp rig. Put it in my new one. The only thing I did to it cut the stock switch off since I broke off the tab to on/off the switch and soldered the wires back together so closes the loop. When to turn on the rig and it power up and get steering and dig servo. But it will not arm itself and I get no throttle,everything else works though. |
08-18-2008, 12:25 PM | #1017 |
Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
Hey jrh is this still on the back burner or is it still in development. I am wanting one and looking foward to this http://holmeshobbies.com/product.php...&cat=17&page=1 Thanks chad |
08-18-2008, 01:01 PM | #1018 |
[HOONIGAN] Join Date: Jan 2008 Location: Littleton
Hey JRH, When are you going to have 35 turns back in stock? Also what motor do you recommend for a Slash with stock esc. Thanks, RPMJ |
08-20-2008, 01:44 PM | #1019 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
08-22-2008, 11:55 AM | #1020 |
Rock Stacker Join Date: Apr 2008 Location: Tucson
| cobalt 454
will the 454 fit in an AX-10 with stock tranny? will it work with the Visionary Faberications motor plate? will i need your motor plate as well? will 7 or 8 cell 1500 elite saddle packs work for power with a sidewinder? |
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
