08-22-2008, 03:45 PM | #1021 |
Hi John, you have paypal for that order we spoke over the phone, thanks again and nice talking to you |
08-22-2008, 11:57 PM | #1022 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| CASTLE BEC Order Which output voltage do I use? I'm adding an Ipod stereo amp to my crawler, 6 watts :-P , it takes 4 AA batteries =6+ volts but the ac/dc adaptor plugs into the back where it says 9V input Which Voltage BEC do I need to order Also how do you remove the annoying beep noises from my Mamba max /BM16 setup Thank you for your time Rian |
08-26-2008, 10:14 AM | #1023 | |||||||||
I let this thread go to long without support! Bad JRH! Quote:
I haven't tried the 454 motors in a ax10 yet, and you would need either the visionary fab plate or my own adapter plate. Quote:
You gotta live with the mamba max noise, it is just part of the beast! | |||||||||
08-27-2008, 01:16 PM | #1024 |
Thank you for getting back to us John. So I would need to use 9 volts and not the battery connection at 6 volts ? Why not run 6 volts to the battery wires ? |
08-27-2008, 01:28 PM | #1025 |
You could run 6v to the battery wires, or run 9v to the AC plug on the back. Just depends on how clean you want it to look.
08-27-2008, 07:33 PM | #1026 | |
I stripped out the ipod speaker system. My intuition tells me the 9v would give better sound quality to do 6 watts but I'll try the 6v off the servo cc Bec and see. I 'll later end up with a 2nd bec to run the 9v. Thank you for your time John. | |
08-27-2008, 08:19 PM | #1027 |
Quarry Creeper Join Date: Aug 2008 Location: Yuma
I have an AX10 with a Mamba Max and 7T puller motor. I have 2 850 venom li po packs. 2 questions. 1. Can you recomend 2 packs that will meet the power needs of the 7t motor. I only get about 20 minutes out of this beast and would like more time. I can fit the 1100 mah lipos on the axles, but thats about it, and I do not think they put out enough amps to keep up. 2. Can I charge 2 li po packs ( my 850's together ) if I set the amps to max out at the total mah of the packs (ie. 800 mili amps for 1 pack, 1.6 amps to charge 2). They are wired together now, I have to take them apart to charge them. Thanks Ted |
08-27-2008, 08:51 PM | #1028 |
Rock Crawler Join Date: Feb 2008 Location: Anniston, Alabama
Hi John, You have any idea when you might get the Castle Mamba Max back in stock?
08-29-2008, 10:10 PM | #1029 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
Thanks John... I retry it first maybe i forgot to install something and if it's fail again I will give castle email for this problem. |
08-30-2008, 02:01 PM | #1030 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Do you have or able to sell a cc sidewinder with a pro 540 35t in a combo? I emailed you about going brushless ,but to get what I want out of it perfer to spend the $$$ else where |
09-01-2008, 02:35 PM | #1031 |
RCC Addict Join Date: Feb 2008 Location: Nevada
JRH, I recently bought your EOS0606i charger with balancer I bought a 2 cell lipo battery 2150mah / 20C / VP racing battery the plug on the battery, female 3 hole, dosen't mach up with the balancer 2s slot, it has five pin. Do you make an adaptor for it? also I plugged the cables in, then lipo, then ac (in that order) pushed batt type button once it displays: Lipo CHARGE C=1000mah 2s i hit the enter button, 1000mah flashes, I just increse to 2150 and hold down enter to start charging right? I charged my NiMH's, it is soooo quite compared to my 969 super brain, I didn't even think it was running Thanks Dewayne |
09-01-2008, 05:13 PM | #1032 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Hey John I ordered a 7t a few months ago and now finally getting around to using it. (full size crawler got the best of my summer) I see I should be using a 20C 3 cell lipo, I have a mamba max and bec I could use but wondering if there is something smaller that I could use that will take that much power. Looking for the best performance and if it means using my mamba I will. Thanks John Hope your having a good weekend answering all our questions.
09-02-2008, 08:06 AM | #1033 | |||||
I am not familiar with VP batteries. I would assume that it has 2mm pin spacing if it won't plug into the hyperion ports. Quote:
09-03-2008, 12:37 AM | #1034 |
Rock Stacker Join Date: Feb 2008 Location: on a rock
i sent you an email about my order but did not realize on your webpage it says you dont respond to questions from Hotmail Email |
09-03-2008, 06:02 AM | #1035 |
Generally I can't respond to hotmail. I still try, but they bounce back a lot.
09-07-2008, 10:28 AM | #1036 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Hey John. I'm running a torquemaster 45t/tekin fxr. Whats the setting that changes the smoothness of the low end? It's a little jumpy right now. Thanks |
09-09-2008, 11:56 AM | #1037 |
What gearing and voltage are you running? Tis a smooth combo straight out of the box, maybe some binding in your drivetrain or a gearmesh issue? Possibly your radio? Have you reset your throttle endpoints?
09-09-2008, 01:21 PM | #1038 |
Newbie Join Date: Aug 2008 Location: FT Bragg
I will be ordering your X-Caliber 25C 11.1v 2200mah lipo, Hyperion EOS0606I AC/DC Charger and the LBA 10 Multi Balancing Adapter for the charger. On the LBA 10 is asks me to Choose Balancer Type, which one do I need for this charger and battery? Also do you know if anyone is running your Cobalt Puller 7T in Berg axles? |
09-09-2008, 01:34 PM | #1039 |
I am running 5t pullers in my berg. They fit will the lower links outboard on the mounts. You can use the balancing adapter that comes with the hyperion, just plug into the 4s port with the pack negative on the most negative terminal. |
09-09-2008, 02:25 PM | #1040 |
I am trying to order your X-Caliber 25C 11.1v 2200mah lipo. I am in the Army in Iraq and your site is not letting me enter a APO AE address. Anyway you can help?
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
