11-07-2008, 07:45 PM | #1161 | |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
Quote: Quote:
11-07-2008, 08:07 PM | #1162 |
RCC Addict Join Date: Feb 2006 Location: ccxc
status on puller brushes?
11-08-2008, 12:31 AM | #1163 | ||
The battery would be boarderline on power. Don't thrash it too much and you would ok, but I personally wouldn't use the pack. 40 amps discharge is my recommendation, double of that pack. Quote:
Quote: In stock on my site, and stocked on my shelf. | ||
11-08-2008, 11:02 AM | #1164 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
Ok. Do you have a battery that is 3.5 inches long or less that you would recommend. How about the xcaliber 1300? Isnt 40amps but alot more than the 1500. Oh and another question. If I decide not to go with the cobalt because of batteries, Is the 30t handwound pretty close to the cobalt? How different is the 30t from the last batch of HHH with the 4 magnets? Can a 30 handle 3 cell? Thanks Last edited by rc4x4crawler; 11-08-2008 at 03:19 PM. |
11-09-2008, 07:26 AM | #1165 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
JPH, I'm looking for a motor with more umph than the TorqueMaster Mini that I can bolt into an AX10 tranny. It's for a 1.9 and looking on your site I came across the 454 & 500. The specs on your site confuse me because it looks like the 500 is slightly longer and wider but weighs less? 454: 28mm x 50mm 8oz 500: 28.9mm x 54.3mm 6.4oz As far as performance, how do they stack up against a regular Integy 45t and each other? Thanks Last edited by Locked Up; 11-09-2008 at 01:52 PM. |
11-10-2008, 02:17 PM | #1166 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Hey John,I was wondering if you had any cobalt puller motors on hand?Also which would be best for my 2.2 rig you seen at hobbytown the other day,5t,7t?Also will those motors work with my cc sidewinder and that 8 cell I got from you?If not I may need more than just a motor.I think Harley's gonna get mad at me,I have 2 3/8" clearance in that chassis I got from him from the motor plate to the edge of the chassis.Might have to grind a little to make this motor work,but I would rather have this than a 35 or 45 turn 540 hand wound ,well i think..Point me in the right direction for a super powerful crawler setup for my comp rig.Not sure the 8 cell and standard 45 turn brushed motor with that sidewinder is gonna cut it so I would like to get some ideas from you.I like Tekin products,You got anything going on with them?Or is a mamba max IYO better than the FXR Tekin?Just get back to me when you can with your ideas and I will try to meet up with you again this week sometime and get some more stuff from you.All else fails I will need a 35turn handwound from you for sure..If you have one of them... |
11-10-2008, 05:15 PM | #1167 |
Newbie Join Date: Oct 2008 Location: London
| mamba 25 esc.
Hello, I was chatting with Joe Ford from castle creations and He advised me to get a second opinion from you on this subject. The question I have is around here but I have yet to see professional answer.... I am running a 16.5" super clod crawler with novak 55t motors on LRP speedos(dual electronics) and I have 2 mamba 25's here. I know how capable they are with tuning and would like to use them instead. With to firmware update available, can I run the 2 55t brushed 540's on mamba 25's? And if so, what is the max for battery power running SAFELY? What else do I need to know about the subject? Any and as much info possible is grately appreciated!! Thanks in advance! twitch1 |
11-10-2008, 05:36 PM | #1168 | ||||
The 1300 Xcaliber battery would be pushing IMO, but honestly it would work fine with the cobalt puller. I like to overestimate your needs so that batteries will last as long as possible. Quote:
As compared to a 45t integy they have more speed and a bit less torque. Not a big suprise to me since they weight less however. I need to find a way to compare then straight up. Quote:
11-10-2008, 05:39 PM | #1169 |
Ok thanks JRH. |
11-10-2008, 07:53 PM | #1170 |
i have a 7t running on 8cell 1600mah elite pack. I am ok with it. Would it be stupid to try your 30t instead on nimh? looking for speed(though the 7t is def pretty quick)
11-10-2008, 08:13 PM | #1171 |
I just saw the weight at the bottom but that must be the total package weight. I see now the weight for the 500 is 4oz, can you tell me what the 454 weighs? thanks |
11-11-2008, 08:16 AM | #1172 |
Well John,if you would set me a 7 turn cobalt puller to the side I will come up and get it from you in the next couple days.Is this motor as fast as a 35 turn on 11.1v lipo?Also,is the 7 turn well suited for my application or do I really need a different turn like the 5 turn?And which one of your lipo's do you recommend for this motor?Is the Tekin FXR just as good as the mamba max?Just curious cause I thought you had a mamba max in everything....And where you wanna meet at this time?I can come up wednesday or after any day.Can I just come by your crib and check out your surplus of goodies and see what else I can buy?I might need more than a just a motor.. |
11-11-2008, 06:12 PM | #1173 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
Hey JRH, Can you let me know when you get some more 45turn torque master's. I am in need of one. thanks
11-12-2008, 09:06 AM | #1174 |
Quarry Creeper Join Date: Jul 2007 Location: Powder Town
Can a Tekin FXR handle a 3s lipo with a 7t puller or should I use an ESC with more power overhead? Thanks for the help... |
11-12-2008, 08:02 PM | #1175 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
JRH- I was wondering if your 18% off sale is still on? I've been thinking of switching to a tekin fxr & trying one of your new .500 motors. How much would that combo be right now? Currently I run a mamba max & 45 turn integy pro with a 1550 maxamp 11.1 lipo in a gc1 with axial trans & axles. Would this setup work similar to what I have now? I'm pretty satisfied with how it works now, just looking to save a little weight & was thinking of running the mamba max in my wk basher with a cobalt puller or 2-3000 kv brushless? It has a goat crawler now & works well but I'd like to volt it up to 11.1? |
11-13-2008, 02:56 PM | #1176 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
| 454's
I want to run two 454 colbalt motors with 9 tooth pinions, Tekin FXR on a 11.1 volt lipo on my HR MOA rig. It weights just under 5 pounds RTR. Will the motors hold up to the 11.1 volts?
11-14-2008, 02:39 PM | #1177 |
*tap tap* *blow* Testing testing, this thing on?
11-16-2008, 02:16 PM | #1178 |
Another question.... Do you think a tekin FXR or sidewinder can handle 2 of your 540 handwound 45ts in a Berg? if not, what about the FXR pro or a Mamba max? |
11-16-2008, 02:30 PM | #1179 | |||||||||
Whoa! Take a few days away from the thread and get another page! Lets get crackin. Quote:
The FXR is plenty for the 7t on 3s, but you will need a BEC. Quote:
With a Cobalt 500 you will get a bit more speed as compared to a 45t. Torque very similar. Quote:
45t, on 2s lipo yes on FXR. The FXR pro, sidewinder, or MM, yes on 3s lipo. | |||||||||
11-17-2008, 01:00 AM | #1180 |
RCC Addict Join Date: Nov 2008 Location: never been
ordered my torquemaster mini last friday for my MRC, i will be flipping the tranny when i install it and need to learn how to zero or reverse the timing, also which of those two would you suggest is better ? TIA
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
