11-17-2008, 01:00 PM | #1181 |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
Got my Sidewinder and 45t HHH, installed them and the servos glitch like crazy. Did not change anything else in my setup, just replaced the Rooster Crawler and Reedy 55t. CCBEC powers directly the 645 and 225 servos and their signal comes via SR3000 rx. This setup finally worked glitch free with the Novak and 55t. Tx is a DX3 and the battery is a 2s lipo. Setup was made with the link. What I was wondering about was the capacitors on the 45 HHH. I cant see any. Website says "Onboard Surface Mount Capacitors – Helps eliminate unwanted radio interference caused by electric motors." Are they inside the endbell? edit: tried the setup with a capacitor ("glitch buster") on the bat slot of the rx, it helped a bit. Only glitches when approaching WOT. Last edited by trainer; 11-17-2008 at 01:12 PM. |
11-17-2008, 01:11 PM | #1182 | ||
Zero timing is good all around. Quote:
It may be the CC BEC throwing off interference. Is the Sidewinder BEC powering the RX? The Torquemaster motor has the capacitors on a little green board on the endbell. Do you see one there? | ||
11-17-2008, 01:52 PM | #1183 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
I just placed an order since the fxr is still on sale. I hope it gets here by friday, there's a comp on saturday
11-17-2008, 01:57 PM | #1184 |
| BEC worked perfectly with the Rooster, Sidewinder powers the ESC. That green board was something I was expecting, but seems like the caps are not there. Here's a pic of the caps in Reedy, nothing in the 45t.
11-17-2008, 02:03 PM | #1185 |
You got shorted the board! Must have had one slip through production with the wrong endbell or something. Yeah, some caps would help.
11-17-2008, 02:29 PM | #1186 | |
unless you have an extra endbell with caps you could send me... I've had bad luck with external caps before. Last edited by trainer; 11-17-2008 at 03:09 PM. | |
11-17-2008, 04:15 PM | #1187 |
RCC Addict Join Date: Nov 2008 Location: never been
[quote=JohnRobHolmes;1432003]I have been setting the timing to zero on all recent orders, I shall change my website to reflect this. Zero timing is good all around. thats perfect, this is by far the best thread here on this board. i will need a hitec 645 and i know where to go. thanks john |
11-18-2008, 10:42 AM | #1188 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
John, What rating Lipo do you recommend for someone running 2 of your 540 handwounds (45t) on a Berg? Last edited by Locked Up; 11-20-2008 at 11:39 AM. |
11-21-2008, 02:56 PM | #1189 | ||
Something with at least 40 amps continuous would be your best bet. A 20 or 25C 2200 pack is what I run. | ||
11-21-2008, 05:00 PM | #1190 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
JRH i have an ax10 i would like to change my stock bec an esc out to after market electrics. I have a axial 55t motor i'm running. i'm also wanting to go lipo, your help and expertise will be greatly appreciated. THANK YOU.
11-22-2008, 01:47 PM | #1191 |
I wanna be Dave Join Date: Nov 2005 Location: Here
John, Have you ever tried a 7T Puller with 4s LiPo??? I know when you originally launched them it was 12v max. Have you ever pushed it to see if it can handle the extra??? It will be for a crawler so it wouldn't be full on all the time. Let me know your thoughts. John |
11-22-2008, 05:52 PM | #1192 |
i got an 1100 mah lipo for my MRC, do i just change the plugs and use it or do i need a new ESC or something else? i have your MTM and am planning to get the hitec 645 and a servo arm for the latter. any info and parts suggestions would be a big help. TIA
11-22-2008, 06:44 PM | #1193 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
JHR, Im thinking of running my Cobalt 7T with my FXR, will I be able to run 3s lipo or would it be safer to stick to 2s with this combo? |
11-24-2008, 07:53 PM | #1194 |
Quarry Creeper Join Date: Jan 2008 Location: In the corn
What is the kv rating of your 5pole motor vs a 55t?
11-25-2008, 02:10 PM | #1195 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
| Burned up my torquemaster mini
I forgot to zero the timing when I installed my Torquemaster Mini motor into my flipped trans MRC. Now it's not working very well. It stalls out from time to time and needs a push to get going again. Is it fixable? Do I just need new brushes?
11-25-2008, 02:46 PM | #1196 | ||||
Which one, the cheap one? I think they are 250kv or something, very slow. The 55t is 1000kv The comm and brushes need a cut. | ||||
11-25-2008, 03:27 PM | #1197 | ||
11-25-2008, 03:43 PM | #1198 |
yep, a normal lathe works fine. Cut off just enough to removed the burned part. I generally mark the comm with a sharpie and just take off the ink. You can use 250 grit sandpaper to the brush face.
11-25-2008, 04:30 PM | #1199 | |
11-25-2008, 08:02 PM | #1200 |
Well I got my fxr & 500 motor on friday, installed them the night before the comp. Needless to say I stayed up a little too late but got it dialed & it worked great. Thanks JRH!, love that motor & esc. I was wondering if I need the optional "outrunner" motor plate (ax10 trans) for my motor or is it a different size altogether?
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
