12-16-2009, 01:46 PM | #1961 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
John I sent an email also but then I seen this customer support thread. Can't get my brxl to work. It had reverse only at first, tried recalibrating & now it does nothing only the red light comes on. My castlelink v3.220 recognizes it's connected but when I try to send an update it says " error communicating with device did not receive a response from controller try unplugging and reconnecting usb device" which I do & still nothing. Is it no good or could I possibly be doing something wrong? Help!
12-16-2009, 01:49 PM | #1962 | |||
12-16-2009, 03:14 PM | #1963 |
haven't gotten an email, did it go through?
12-17-2009, 06:54 PM | #1964 |
OK got the email and the speed control working thanks JRH |
12-19-2009, 12:12 PM | #1965 |
Quarry Creeper Join Date: Jan 2008 Location: marysville
Hey JRH, just a quick question about the Revolver Black... Whats the max amps that motor will pull?? My crawler is the only rig not getting any LiPo lovin' so Im gonna pick up a 2S, maybe 3S, for it and want to make sure it will supply the load. Thanks in advance man!! |
12-19-2009, 03:08 PM | #1966 |
Quarry Creeper Join Date: Sep 2008 Location: everett
Hey JRH, question for you? I am building an 8x8 and was thinking of a way to use one motor and esc, would a 7t puller and your new BR-XL with a 4s-6s be enough? Any other recommendations would be great. Thanks Derek |
12-26-2009, 09:42 AM | #1967 |
Quarry Creeper Join Date: Oct 2009 Location: 707
Quick question. So i ordered my BR-XL yesterday, and was wondering what my best motor option would be? its too bad the 7t puller is already gone.. Wheelspeed, torque, and steadyness is what im going for. also looking to run it on 3-5s lipo. |
12-26-2009, 12:40 PM | #1968 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
I apologize if this is a duplicate question, but I read you were coming out with a 16t puller? Is this true, and do you think it will run cooler in my 10lb Super than my 10t. Twin Force based, 3S 2200mah polyquest lipo, FX-R, 54:1(roughly) final Ratio. Also I have a post in the Electronics Board concerning a Hitec HS7955TG servo and a glitch. Could you give me some insight on my issue. Thanks Eric |
12-28-2009, 12:46 PM | #1969 | ||||
The motor can actually pull a few hundred amps on startup, for very brief periods of time. Quote:
12-28-2009, 05:38 PM | #1970 |
Newbie Join Date: May 2009 Location: Littleton
| 24p Pinion ?
Do you know where I might find a 24p pinion gear to fit one of these motors (Crawlmaster 3014 850kv): http://holmeshobbies.com/product.php...&cat=24&page=1 I bought some 8ight-T gears which have the right pitch: 24p, but unfortunately was not paying enough attention to the shaft diameters, they expect 5mm shafts, these motors' shafts are much smaller ~1/8". I'm building a vex based robot. All of these gears are 24p. http://www.vexrobotics.com/vex-robot...gear-kit.shtml Some short of shaft coupler or converter / gear box would probably work too. Or some motors with 5mm shafts (torque more so than speed, preferable). |
12-28-2009, 09:16 PM | #1971 |
I have some replacement shafts I can send to convert the motor to 5mm if that helps.
12-28-2009, 09:32 PM | #1972 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
Hello, I am planning on buying a set of HH 35T hand-wounds for a berg. Do you suggest changing the timing 180deg or just reversing the polarity for the rear motor? |
12-28-2009, 09:36 PM | #1973 |
Either way, just be sure you aren't getting arcing on the rear motor. If I break in the motor clockwise, the timing may change a bit if it is spinning the other way.
12-29-2009, 08:27 AM | #1974 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
Hey John, what turn of your mod motor would you suggest for a clod base crawler running 3S Lipos and 2.2 tires? Just for crawling not speed. Thanks Joe |
12-29-2009, 08:41 AM | #1975 |
I would run a 35t, but the average person running 12t pinions would use a 55t.
12-29-2009, 04:52 PM | #1976 |
wouldn't the 55's give me more torque compared to the 35's? I don't need speed, I was thinking about the 100:1 gear set, I want massive torque. (poor cvd's) |
12-29-2009, 06:08 PM | #1977 |
Pebble Pounder Join Date: Nov 2009 Location: eastside of the 808
I'm kind of new to all this Lipo technology. I was wondering if your Hyperion EOS0606I charger and 3s lipo pack are completely compatible? By that I mean, would I need any other type of adapter to charge the battery? I have already purchased a bec from you but would really like to know if I need anything else to run 3s lipo. Thanks
01-04-2010, 11:20 AM | #1978 |
Rock Crawler Join Date: Mar 2008 Location: lodi
my buddy let me use his 10t puller yesterday in my scaler, it kept loseing its timeing and i had to keep fixing it every 15 mins or so is there something i can do to fix this for him? i know he wa having problems with it also and wanted to get it fixed for him. and because of the timing problem the com looks burnt. this motors awsome in the scaler just enough wheel speed and all torque i could need but with the timeing problems it makes it more work then i want to do to be able to play with my fun scaler.
01-04-2010, 01:53 PM | #1979 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
John, I am trying to use a $50 gift certificate I was given for Christmas to order some things off of your site. I followed the instructions in the email that the code was send in but in step #5 it tells me to "Select gift card as the payment method" but I don't see a gift card payment method option when I check out, I only see "money order" and "paypal/cc". How do I cash in the gift certificate? The order number I am trying to apply it to is: 4478.
01-05-2010, 03:25 PM | #1980 |
Quarry Creeper Join Date: Jun 2008 Location: Honolulu
I'm going to order some new lipos for my mrc and was wondering how much amps your TM mini motors pull? I'm looking at getting some 360mah 25c 3s. TIA
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
