Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: MT Venture
Old 12-25-2017, 10:44 AM   #1
Default MT Venture
Wife floored me with a HPI. I'm super pumped as hpi was what got me into this addiction so as soon as I seen it I wanted no matter how it worked. Pleased to see it can hold it's own and they did their research.
TAT76 is offline   Reply With Quote
Old 12-25-2017, 11:25 AM   #2
Default Re: MT Venture
Nice gift. Enjoy the truck!
Sent from my LG-H931 using Tapatalk
soze is online now   Reply With Quote
Old 12-25-2017, 12:21 PM   #3
Sweet! Change that Servo quickly. Other than that it’s awesome
Jfrisch01 is offline   Reply With Quote
Old 12-25-2017, 05:36 PM   #4
Going to the lhs first thing to see what they have but may have to order as I need a new rx aswell. I've only had a few min to look it over but the links have to go so I hope i can either find a set compatible or we see some shortly.
Old 12-25-2017, 06:24 PM   #5
Couldn't wait, just ordered a protek 370tbl and rx. Should be here Friday.
Old 12-26-2017, 07:31 AM   #6
Had some time to get into the new truck this morning. Very impressed with the quality and design but bummed they held back and went plastic links. This could have put them above the rest and set a new standard with rtr's.
For now I plan to run stock as it's winter and don't see a need to trash good equipment in snow conditions. I removed the battery strap thingy and am using Velcro straps as I find it easier and more secure for my Lipo.
Mounted up the Hyrax 4.19 on axial bl to see how they look. Look a little small to me but when placed with stock their comparable. Once I swap the connector on esc I will do a snow run and report back.
Old 12-26-2017, 08:49 AM   #7
My esc also came off the mount. But that's OK....I changed to the hobbywing 1080 esc and upped the bec voltage to 7.4v since the receiver can handle it.
dwblue00 is offline   Reply With Quote
Old 12-26-2017, 09:27 AM   #8
Just got done with a short snow run. It's 5 degrees out and we have 6-8 inches of fresh powder so I shoveled a trail and then blasted around making my own.. lol it was a hoot and this little truck put a huge smile on my face. The system actually worked great other then the servo which I have on order.
Old 12-26-2017, 10:07 AM   #9
nice!
Old 12-26-2017, 10:40 AM   #10
Something I'm sure everyone knows but hasn't been mentioned is to go threw and loctite.
I think I found a horn that will work but I'll have to wait till servo gets here to see.
Old 12-26-2017, 01:43 PM   #11
Made a prototype platform to test out and see if it'll work. Plan is to drop Lipo down behind tc but don't want to cut battery trey till I have it all figured and parts needed.
Old 12-26-2017, 02:09 PM   #12
Old 12-27-2017, 11:37 AM   #13
Well I was able to hit a local spot of mine today for a 2 mile run. We've had lots of snow so I had to stay on the walked trails but it was fun and challenging. This little truck just works, not once did I have to help it along.
All's good on my platform so far. Electronics seemed to stay put and it helped with keeping snow from packing up on the tranfercase.
Temp: 15 degrees
Condotion: Snowcover/chains recommended
Distance: 2 miles
Old 12-29-2017, 06:58 AM   #14
Yesterday I worked on relocating the battery down on the platform. Made myself a little mount and used straps to secure. Nothing fancy but it gets the job done.
Old 12-29-2017, 01:38 PM   #15
Got some goodies today. New servo Protek 370TBL is pimp with butt loads of torque 600oz at 6v. Waterproof rx showed so now I can use my mx-v to run and not worry about my high dollar race TX.
Old 12-31-2017, 07:39 AM   #16
Cut up some wells yesterday to help keep the cleanup to a minimum. After a snowy run to test I'm happy with the turn out and can paint them up.
Old 01-01-2018, 07:34 AM   #17
Had some fun setting up rock lights. Waiting on a light kit before finalizing but wanted to get an idea of what I was dealing with. May need to tone down once others are added.
FPV was just for fun but after running I may build it on a mount to easily be able to install or remove. Something about sitting inside and driving the neighborhood just made me giggle.
Old 01-07-2018, 06:12 PM   #18
Hooked up #scx stock wheels/tires just to see if I liked a taller tire. Now I'm thinking of mounting some Klr's..
Old 01-07-2018, 08:51 PM   #19
Wow! I guess I found where you went.
How would you compare the Venture to the Scx10 II?
lonleycreeper is offline   Reply With Quote
Old 01-08-2018, 06:22 AM   #20
Lol! I'm all over the place this time of year. ;)
So far I think the hpi is going to give axial a good strong run pushing the industry to rethink to stay on top. I find it to be a very capable little truck and the quality of the plastic is up there. Of course it's new and being snowy it's hard to get a good run but as of now it's my go to truck for fun all around excitement.
MT Venture - Similar Threads
The venture is here! Jfrisch01 HPI Venture 127 03-06-2018 07:34 PM
Just ordered a venture dwblue00 HPI Venture 39 01-07-2018 06:35 PM
No HPI Venture Frank211 General Scale Talk 111 12-14-2017 04:55 PM
My HPI Venture is on it's way... QuesoDelDiablo 1.9 Scale Rigs 86 11-29-2017 04:58 PM
Another venture. aubie Chit Chat 6 12-25-2005 05:35 AM
