12-15-2018, 03:32 PM | #1 |
Rock Stacker Join Date: Jul 2010 Location: North East
| Venture ESC question
Can’t seem to get reverse to work in my venture. It has the stock hpi sc-3swp3 crawler spec speed control. Forward works fine. When I try reverse, the esc just blinks red quickly. The jumpers only adjust drag brake and battery type. I cannot find any other info on it it terms of resetting it or calibration etc. Any ideas? Thanks |
12-16-2018, 09:12 PM | #2 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
| Re: Venture ESC question
Hey man, my internet troubleshooting points to a faulty ESC. So while it'd be nice to find some programming or calibration settings to adjust, I don't think the stock HPI ESC has any of that stuff. Sounds unfortunately, like a warranty claim if you're running a new Venture. |
12-17-2018, 09:48 AM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
What radio are you using? Does it have ABS enabled? Did it work before? Have your tried rebinding it? Are you sure the motor is good? |
01-20-2019, 02:32 AM | #4 |
Newbie Join Date: Dec 2018 Location: dammam
Hi guys, a newbie here and to the hobby itself. I have a question & I really hope you guys can help me figure things out. I recently purchased my first ever RC vehicle, the hpi venture. Everything's stock except for a cheap 20kg annimos servo that was thrown along with the package which I ended up changing myself.Was running it the other day and i got a bit carried away and drove it through some really wet and muddy stuff. Switched it off soon after. Took it home and spend a good couple of hours cleaning it up. There was mud all over the place. Tried turning it on and found that the esc didnt make the usual beeping sound during start up. The steering works fine but there's no throttle response. The esc just keeps blinking when I pull on the throttle. No sound from the motor either. I tried switching the servo & throttle ports in the receiver. Still nothing. What could be the problem? Will I need to replace the ESC or the motor? or is there an easy fix? Thanks |
01-21-2019, 11:37 AM | #5 | |
| Re: Venture ESC question Quote:
Could be a dirty motor. Rinse it thoroughly with clean water, dry it completely (use compressed air if you have it) and oil the bearings. Try that. Also, see if the motor engages by giving the truck a push while you apply some throttle - that can show you if the motor is worn out. | |
01-23-2019, 09:48 PM | #6 |
As Queso said, the motor is the most likely culprit among other possibilities. Brushed motor bearings tend to die quickly when exposed to excessive mud/dirt/sand/dust/water. If those bearings are toasted, then the motor shaft will be too seized up to spin. Fortunately, if a dead motor is the case, they're fairly cheap and easy to replace. Let us know what ends up fixing it. |
Venture ESC question - Similar Threads | ||||
MT Venture | TAT76 | HPI Venture | 51 | 01-29-2020 12:32 AM |
All out venture | hoghead5150 | HPI Venture | 5 | 11-25-2018 10:03 PM |
The venture is here! | Jfrisch01 | HPI Venture | 127 | 03-06-2018 07:34 PM |
My HPI Venture is on it's way... | QuesoDelDiablo | 1.9 Scale Rigs | 86 | 11-29-2017 04:58 PM |
Another venture. | aubie | Chit Chat | 6 | 12-25-2005 05:35 AM |
