Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: 3D printed parts for the Venture database
Old 03-20-2019, 07:13 PM   #1
Post 3D printed parts for the Venture database
I thought it might be nice to have a list of 3D printed parts available for the Venture. I was thinking maybe limit this to just free files but I suppose adding in stuff thats not free would be just as helpful so go for it.
I just put a Rear Crossmember up on thingiverse, anyone can download and print it. 2 versions one basic the other is beefed up a bit.
https://www.thingiverse.com/thing:3506581
Max Gear Down Motor Mount
https://www.thingiverse.com/thing:3569491
Venture Max Gear down Motor Mount
User Warmage on Thingiverse has a few rear crossmembers too as well as a battery tray.
Rear crossmember
https://www.thingiverse.com/thing:2948839
Rear crossmember
https://www.thingiverse.com/thing:2790470
Battery tray (needs some trimming to work with BowHouse skid to clear the driveshaft and transfer case)
https://www.thingiverse.com/thing:2942916
also a high clearance rear bumper for the FJ
https://www.thingiverse.com/thing:2925486
Bumper/winch mount (not servo winch)
https://www.thingiverse.com/thing:2899413
SCX10.2 Bumper
Originally Posted by Captain_Torquepants View Post
This bumper fit my Toyota body very well.
https://www.thingiverse.com/thing:3508691
I just added a wire holder for the electronics tray that can hols bigger 4mm wires, 2 versions for brushed motors though brushless guys can likely use the one called V3 it has a hook on top that I use to keep the wires for my lights out of the driveshaft and you can probably use this for the third motor wire.
https://www.thingiverse.com/thing:3608300
Rear shock towers with narrow body mounts made for the Proline Power Wagon body. I've lowered the mount by 1 hole and moved them inwards by about 7mm. You will need to cut up the bed to clear the shocks and shock towers and the stock body mount holes are right near the edge of this cutout so I've moved them inwards to retain more strength.
https://www.thingiverse.com/thing:3608348
Thats just what came up on thingiverse, please feel free to add to this list or share your own parts if you have some.
HumboldtEF is offline   Reply With Quote
Old 03-21-2019, 08:18 AM   #2
Default Re: 3D printed parts for the Venture database
Rear crossmember
Rear crossmember
Very nice idea. I like the rear braces and battery tray. I assume you need an account to see the other links. After that I need to figure out how or where to print some of these parts.
carpetfuzz17 is offline   Reply With Quote
Old 03-21-2019, 10:01 AM   #3
You should be able to view and download all of the Thingiverse items without being signed in. I just double checked and I can view and download when logged out. Links are all working for me.
One thing it might be is just the site being slow to respond, its pretty bad sometimes. It will often take a refresh to get some pages to load.
Old 03-21-2019, 10:14 AM   #4
All I can see is gears for the pictures on me end. The bad thing is I don't have or know of anyone with a printer. Sucks to be me
Old 03-21-2019, 10:19 AM   #5
So the gears will show up before the pictures have loaded so it might be loading super slowly, try refreshing the page to see if it helps. Sometimes pages will just stall and not fully load.
You may be able to find someone local to you who offers prints, thats becoming a lot more common.
Old 03-21-2019, 10:21 AM   #6
Nice, thanks for putting together this thread. I've been downloading whatever I can off thingiverse for the day I finally pony up for a printer.
soze is offline   Reply With Quote
Old 03-21-2019, 10:40 AM   #7
I will have to look into the local thing
Maybe it's my phone that wouldn't let me view them I have tried everything and no luck
Old 03-21-2019, 11:08 AM   #8
Good idea!
I use the battery tray and crossmember from Warmage on mine as well as the high clearance bumper. Works really well
MartinKyx is offline   Reply With Quote
Old 03-21-2019, 11:56 AM   #9
Moderator
JatoTheRipper's Avatar
Great idea! This print database should exist for every RC.
Old 03-21-2019, 01:19 PM   #10
I made some servo shims to compensate for deleting the the servo saver, if I can ever make time to log in and upload them I'll post a link for them in here.
QuesoDelDiablo is offline   Reply With Quote
Old 03-21-2019, 05:31 PM   #11
This is a cool idea and I agree, should have one for every rig. Thanks!!
TAT76 is offline   Reply With Quote
Old 03-25-2019, 08:41 PM   #12
Captain_Torquepants is offline   Reply With Quote
Old 03-25-2019, 08:47 PM   #13
Ok I guess I forgot or never hear the spacing was the same for the SCX10.2 bumpers. That could open up a ton more options for printable bumpers
Old 03-25-2019, 09:18 PM   #14
It's not the same as the normal SCX10.2 bumpers. It's only the same spacing as the Axial Poison Spider front bumper.
JDM74 is offline   Reply With Quote
Old 03-25-2019, 09:21 PM   #15
Ok thanks for clarifying
Old 03-25-2019, 09:54 PM   #16
That is not correct. I just checked me Axial stock mount and a Traxxashit mount and the stock HPI bumper will NOT fit in them. The post spacing on HPI narrow compared to the other 2
Old 03-26-2019, 08:24 PM   #17
Weird. I didn't make any modifications. Just printed it and it fit perfectly. Had to grind a half inch off the mounts so it would slide all the way back but the spacing was perfect.
Old 03-26-2019, 08:43 PM   #18
Venture on top SCX10.2 on bottom
scx10.2 looks to be 43mm
Venture is 40mm
They are different
But I suppose someone might come up with a adapter that uses the Axial spacing for use on the Venture.
Old 03-26-2019, 10:22 PM   #19
Venture is 40mm
They are different
RC4WD already has aluminum front and rear mounts out
Old 03-27-2019, 05:37 PM   #20
Dude wasn't very precise with his mounting post diameter. The posts on the bumper are a little smaller in diameter than those in the pic. Looks like they would rub the inside of the Axial holes whereas they rub the outside of the HPI holes. Slides all the way in and doesn't snap the pegs off though so it works for me. Gonna use ABS next time now that the weather has warmed up a bit and I can move the printer out to the garage.
Good to know about the RC4WD mounts.
3D printed parts for the Venture database - Similar Threads
What RC parts have you 3D Printed???? vwdaveb Tools, and Procedures 353 02-08-2023 02:49 PM
3D Printed Parts monkeyracing Tamiya XC/CC01 5 05-29-2015 10:20 AM
