Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Axle swap
Old 03-18-2020, 12:18 PM   #1
Default Axle swap
Who's put different axles on there fj? Apparently it will give you under drive ability.
crazee horse is offline   Reply With Quote
Old 03-18-2020, 05:38 PM   #2
Default Re: Axle swap
The only way to get underdrive in the venture is this transfer case, this will give you 30% ud.
https://deadloc-racing.myshopify.com...16727917264967
You might be able to get an rc4wd underdrive t-case to work as well, this has a variable amount of ud.
https://store.rc4wd.com/RC4WD-OverUn...se_p_7141.html
If you are set on an axle swap, then you will need to find an axle that spins in the same direction as the stock axle. Then, you will need check the gear ratios. for example, the stock ratio is 13/43, which is 3.307 gear ratio. The scx10II is 8/30 which is a 3.75 gear ratio. If they spin in the same direction then, the swap would give you a 13% underdrive.
PLEASE NOTE: I don't know if they spin in the same direction, this was just an example.
good luck with your hunt.
Dezertdirt is offline   Reply With Quote
Old 03-19-2020, 06:30 AM   #3
Cheers bud been reading up a lot on it, half of which I don't understand lol but looks like it will cost a lot to do. Probably get another truck to add to the fleet.
Old 03-28-2020, 01:45 PM   #4
I’ve considered putting another front axle on the rear to get 4WS but it appears to be too complicated for my abilities. Anybody done this?
smokinapankake is offline   Reply With Quote
Axle swap - Similar Threads
Axle swap? Synister_Intent RC4WD Trail Finder 2 4 02-11-2019 01:58 PM
JK Axle swap Dumptruck 2.2 Scale Rigs 22 06-17-2009 12:13 PM
Axle Swap for CC-01 dimsum86 General Crawlers 6 04-11-2007 10:20 AM
