![]() | #1 |
Newbie Join Date: Nov 2020 Location: eu
anyone using the NWSD Scattergun chassis on his Venture? is it worth the upgrade? ideas /suggestions/photos very welcome merry xmass |
![]() | #2 |
SORRCA Committee Member ![]() Join Date: Dec 2008 Location: Parkston, SD
I have one but haven't decided on a build direction yet. I did put it together for my JK build, but ended up not wanting to undo what I had done already with the stock chassis. There are definite advantages to it, like lower center of gravity, angled skid, shock and link geometry adjustments. All the stock chassis parts will bolt up fine, but you will need some 3mm x 5-6mm spacers for the upper link mounts at the chassis for the rear links and for the front upper third link if you choose to use the chassis optional holes. My setup uses a Deadloc t-case and skid and modified steering. ![]() ![]() ![]() ![]() |
![]() | #3 |
thank you so much for the info and picture! Wonderfull build! The picture were you have the two frames (stock and nwsd) ot top of each other is very helpfull, thanks again
![]() | #5 | |
| ![]() Quote:
10.2 made into truggy..... ![]() ![]() 10.3..... ![]() ![]() | |
Tags |
chassis, nwsd, scattergun, venture |
G-Speed v3 or scattergun??? | xxlostonexx | 1.9 Scale Rigs | 3 | 11-22-2020 07:54 AM |
NWSD Scatter Gun chassis | rob5059 | Traxxas TRX-4 | 2 | 10-22-2020 05:22 AM |
NWSD Chassis for HPI | MOmo | HPI Venture | 4 | 05-03-2020 12:39 PM |
