| | #1 |
| Quarry Creeper Join Date: Jan 2008 Location: Essex, UK
| I need to get some lower shock mounts that will rotate the mounting eye of the shocker 90* so it runs in line with the truck and not across the axle like it does now. Does anyone make a billet set? I have looked around and can only find ones that keep the mounting eye running inline with the axle. I dont want to rotate the mounts as I like the fact the shocks acts on the top of the axle. Any help welcome Many thanks, Simon |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| You're not making a lot of sense. Are you trying to keep the shock mounts on top of the axle or trying to move them behind the axle? |
| | #4 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| He is just looking for something that will turn the lower eye 90* so it won't be in a bind. HPI is coming out with some crawler specific parts: http://hpiracing.com/products/en/87633/ Some people (myself included) made our own setup: http://www.patricksnorton.com/WK/tec...linkmounts.php Others just rotate the stock brackets... |
| | #5 | |
The HPI crawler kit would do the trick, but I only need the lower shock mounts and they probably wont sell them seperately, so looking to get some ally/billet ones... | |
| | #6 |
| Ahhh... Now I understand. If you can't find any just try and make some yourself. I feel a lot more accomplished when I fab something myself rather than buying it. Of course there's always instant gratification in buying a part and slapping it on! |
| | #7 |
| Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
| have you checked out tcscrawlers they have some sweet delrin ones that keep the shock on top and the link mount straight with the axle here is a link to them http://www.tcscrawlers.com/TCS-Wheel...n-p-16557.html |
| | #8 |
| Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
| Speaking of link mounts, when is hpi's new kit coming out? Im holding a build waitin for it. |
| | #9 | |
| RCC Addict Join Date: Nov 2007 Location: Scalers are more fun
Very nice mounts, and delrin is plenty strong. I love mine. | |
| | #10 | |
smcurry83: I prefer to slap it on lol! Does anyone have an answer to Magics question of when the HPI kit is coming out? I'd really like to know that to.... | |
| | #11 |
| | #12 |
| Pebble Pounder Join Date: Jan 2008 Location: midvale, Utah
| | #13 |
| Decaur: So simple yet so effective, might try that and see how I get on, seeing as its free |
| | #14 |
| yea I was a little worried about that, but it has held up fine... I figure it should last long enough for the new HPI mounts to come out.... as it is the end of the bolt is aimed just slightly above the other hole, so going all the way through might introduce some binding..... let us know how it goes if you try it... |
| | #15 |
| Rock Crawler Join Date: Dec 2007 Location: USA
| does anyone have another way other then dacars way? i have heard to rotate the shock mounts so that the top of the mount is facing the middle of the chassis but when i do that with the strc kit my shafts hang below the links |
| | #16 |
| if you were to rotate them, the shock mount would actualy be facing away from the chassis,, with the 2 holes facing toward the chassis, and then you would put the shock in the top hole and the links in the bottom hole. the only problem with rotating the links, is they are keyed to the axle to go only one way.. so rotating them isn't really ideal in my opinion. the other problem is that you will have to adjust the link length to compensate for the new location. |
| | #17 |
| [quote=dacaur;1058056]if you were to rotate them, the shock mount would actualy be facing away from the chassis..quote] woops thats what i meant |
| | #18 |
| Oh you mean the driveshafts? Yea thats a problem. got any pics of your setup? it could be as simple as just needing to rotate the pinion up a bit more.... |
| | #19 |
| this isnt my truck but its the same exact set up as mine i just have silver links and color doesnt matter but yes i meant driveshafts Quote: |
| | #20 |
| You need to extend the upper link. look at the pinion angle of the front axle there (non-rotated mounts) thats what it should look like. The problem is that by rotating the mounts you are effectively lengthening the lower links, but you arent doing anything with the upper links. Extend the upper links to get the same pinion angle, and it should be fine. |
| Thread Tools | |
| Display Modes | |
