Thread: my WK Widow
Old 02-15-2008, 11:19 PM   #1
Default my WK Widow
here it is so far. built a upper tray for my electronics. spectrum radio system in the mail. along with a front axle servo mount. i traded out my old wk shocks for some traxxus big bore shocks. i also limited the travel internally about 10mm. you can tell the flex difference in the two bottom photos. first is the new shocks, last pic is with stock wk shocks. lemmie kno what you think.
Click the image to open in full size.Click the image to open in full size.
phase10 is offline   Reply With Quote
Old 02-15-2008, 11:34 PM   #2
Nice build Stuart, can't wait to see it out on the rocks.
LosiDvr is offline   Reply With Quote
Old 02-15-2008, 11:38 PM   #3
thanks man. im also gettin some rc4wd rear lockouts. hope it works well, whos this anyways i see ur in slc
Old 02-16-2008, 07:49 AM   #4
Nice. How did you cut the chassis out? Looks really clean. I'm getting a set of big bore shocks too. What'd you use to limit them?
smcurry83 is offline   Reply With Quote
Old 02-16-2008, 09:33 AM   #5
i used some rubber hose from my lhs. i think its a gas line normally.
Old 02-16-2008, 09:43 AM   #6
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Lookin' good. That looks a bit better on the flex...it's a bit more in check now Have you thought about getting a different batt pack made for it? Those stick packs are so large and cumbersome to work with. You can pick up a very nice 2/3A Elite 1500 8 cell custom pack from Cheap Battery Packs for under $30. I bought numerous packs from Chris over there, and they are always top notch.
Offroader5 is offline   Reply With Quote
Old 02-16-2008, 11:01 AM   #7
That looks great. Good job
What lower links and rod end are you using? I really like how it turned out and am in the process of getting everything together for mine. So if you could give me any info on what I will need it would help a ton. Thanks
TAT76 is offline   Reply With Quote
Old 02-16-2008, 11:31 AM   #8
thanks. i was thinkin of going lithium just cuz i like how small the batterys are, the charger is expensive tho =P but thats what i think im gonna end up doing. ill check out what you were talking about tho, any links to them?
Old 02-16-2008, 05:35 PM   #9
Offroader5's Avatar
Just go to "Packs"...then "Custom Packs". It then will ask you cell count, which cell you want, configuration, and wire size.
Cheap Battery Packs
Old 02-16-2008, 10:27 PM   #10
This is Chris I am buying your lower suspension links.
Old 02-16-2008, 11:06 PM   #11
just got my body mounts and my Spektrum dx2.0. i also chopped up the read end of my body. i was gonna get a losi grappler body but decided to keep it gangsta with the wk body =P heres some pics of how the body turned out.
lemmie know what you think
Old 02-17-2008, 02:03 AM   #12
truck is looking good. thanks for sharing
Old 02-17-2008, 11:25 AM   #13
Offroader5's Avatar
Nice dovetailing
Old 02-17-2008, 02:06 PM   #14
Nice dovetailing
thanks offroader =] i cant wait to get my servo mount so i can get this beast on the rocks man!! i honestly cant wait i think imma just go roll it around on the rocks to ease my pain
Old 02-17-2008, 05:21 PM   #15
so i thought i was jsut kidding at first but i really couldnt wait till monday-tuesday when i real servo mount gets here. i made one out of my cutting board.
havin some problems where instead of flexing the axles just stay straight. i think my shocks are just too stiff. not sure what to do tho really.
Old 02-17-2008, 05:34 PM   #16
soo i recharged my battery and went out again and now my transmission is makin noises. not like everyone says its clicking. its more like. wawaawwawawawa. some wierd noises iuno. im geussing my gears are getting stripped? any ideas?
Old 03-02-2008, 08:08 PM   #17
Default Update
just got some offset stampede rear wheels and some Proline Badlands, thought id take some pics. my width is about 10.5" instead of 11" now. haven't glued the tires yet i think imma get a set of Aces memory foam inserts. prolly do a channel cut down the middle also. im gonna have to get a new servo mount now that i got the offset wheels tho.. any advice lemmie kno..
Old 03-02-2008, 09:26 PM   #18
sourdojack's Avatar
Default wheel offset
On those stampede wheels you can easily cut the inside ring off, file it down, and narrow the wheels 1/4". That should give you the clearance from your servo mount and also make those badlands work a little better.
Here is the link on how to Narrow those Stampede wheels...
http://rccrawler.com/narrow.htm
TOM
sourdojack is online now   Reply With Quote
