Thread: Suspension compression winch on the WK
Old 02-17-2008, 06:03 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default Suspension compression winch on the WK
Anybody else do this?
http://www.youtube.com/watch?v=urm__u9HRnc
I'm wondering if it would be beneficial to add one for the rear or if that would just be over kill?
Locked Up is offline   Reply With Quote
Old 02-17-2008, 08:10 PM   #2
I would think it would be like a 1:1. It might help in extreme climbs, but I think I would rather use my 3rd channel for a dig.
juststartin is offline   Reply With Quote
Old 02-17-2008, 08:34 PM   #3
Locked Up's Avatar
True ... but I already have a dig.
I have done a little testing with this and I'm thinking that the rear would be helpful, but I think probably not worth the extra weight up on the chassis.
Old 02-17-2008, 10:30 PM   #4
I think it would be more beneficial on the front axle. You could winch in the axle on steep ascents and breakovers to keep COG farther forward. I guess this only applies on sprung front suspension
You dont need to mount the servo up on the chassis. If you mount it on the axle it keeps your weight nice and low. If you dont have room on the axle you could mount the servo on the bottom of your chassis and run the line over a bar or w/e.
HndsWthtShdws is offline   Reply With Quote
Old 02-17-2008, 10:36 PM   #5
How about using one servo to winch down both axles simultaneously?
chrisjlittle is offline   Reply With Quote
Old 02-17-2008, 11:16 PM   #6
Having seperate control would be best for anything, good idea but would hinder at times. I tried it with a tlt once, sometimes it helped, others it hurt,
Magic is offline   Reply With Quote
Old 02-18-2008, 12:38 AM   #7
Locked Up's Avatar
USRCCA rules made me think the winch had to attach to the chassis and the line had to go to the axle... section 2.1.4
http://www.usrcca.com/rules2008.pdf
