| | #1 |
| Quarry Creeper Join Date: Jul 2007 Location: Waiting on the world to change
| Waiting for $ to build up my crawler has left me with a ton of time to sit in my shop and think. The WK axles are notorious for having crappy link mounts, I didn't feel like spending the coin to buy aftermarket mounts and too lazy to go get some U-channel. I had my dremel and some extra screws and came up with this; ![]() ![]() On a side note i was bored and painted my motor can, check it ![]() ![]() Thanks for reading |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Oct 2007 Location: richmond, va
| no front on pics? looks like a good idea, i have thought about tlt link mounts since i have a set of em, but didnt want to drill into the case, also the new hpi link mounts look promessing |
| | #3 |
| yea you could get those mounts but you still get the extra plastic under the chassis, these have none |
| | #4 |
| | #5 |
| that looks cool, still would probably use tlt lnk mounts first before cutting the stock ones. |
| | #6 |
| Pebble Pounder Join Date: Jan 2008 Location: midvale, Utah
| please make your pictures smaller... we dont all have 24" monitors..... |
| | #7 |
| Ok done |
| | #8 |
| Quarry Creeper Join Date: Jun 2007 Location: Sacramento
| the only thing I could think is that the link mounts could rotate and flex with only one bolt. I saw someone take a tlt link mount and bolt tat to the axle housing. that looked really stout. have you tested it yet? |
| | #9 |
| looks like he has some kind of shim there,.... as long as its shimmed solid I dont see it rotating unless the plastic is flexible enough to let it twist... |
| | #10 |
| Yep alum shim that is gonna get CA'ed to the axle when I get some more CA. The plastic won't let it turn I havent tested it yet, dont have the money to finish the build as of now. |
| Thread Tools | |
| Display Modes | |
