| | #1 |
| Rock Stacker Join Date: Jan 2008 Location: Laurens SC
| Is any one running this? http://www.hpiracing.com/products/en/86336/ I have noticed some wear on my stock ring and pinion and was just thinking about upgrading to this. Or should i just replace with the stock again. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2006 Location: um, Houston?
| The part in the link you posted looks to be higher quality than the drive gears I found in the Wheely King option parts list: http://www.hpiracing.com/products/en/A855/ |
| | #3 |
| Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
| just my .02 cents but i would go with the r&p from rcp crawlers http://rcpcrawlers.com/product.php?p...&cat=23&page=1 or the hpi r&P #A856 and #A857 and they are hardend gears http://www.hpi-europe.com/piw.php?lang=en&partNo=A856 http://www.hpi-europe.com/piw.php?lang=en&partNo=A857 i have rcp r&p and the teeth on those are really deep and they are pretty heavy |
| | #4 |
| Seems as if #86336 is the same thing as what you posted in 2 links but the US market gets them as a one piece set. |
| | #5 |
| the A856 and A857 are hardend gears and are for the rs4 mt the ones you listed are not hardend gears thats why i listed them cause they are a complete different gear sets the ones i listed are 5mm shaft for the drive lines and the ones you listed are the 6mm shafts |
| | #6 |
| Cool thanks. I am still trying to figure out all this stuff. |
| | #7 |
| Rock Stacker Join Date: May 2007 Location: SoCal
| I'm running the upgraded HPI set in the front of my WK-based crawler. Unfortunately, it's not a direct fit. Maximizer lockers don't fit in the ring gear without modifying them. Compared to stock, the upgraded ring gear isn't as deep where the locker or planetary gears go. The pinion gear is a 5mm diameter instead of 6mm where the u-joint attaches. This means the stock u-joint will have a lot of play. To get rid of this play, you can use a Traxxas T-Maxx 2.5 transmission output yolk and drill the center with a 5mm drill bit (to remove the flat sides). |
| | #8 | |
| RCC Addict Join Date: Jun 2006 Location: Nor Cal
| | #9 |
| Rock Stacker Join Date: Feb 2008 Location: AL
| Did you just swap the ring and pinion or did you have to do any mods to make it fit as stated above Is the rcp crawlers version a literal direct fit...same size shaft, etc? Last edited by ClaySlayer; 03-10-2008 at 10:25 PM. |
| | #10 |
| The pinion shaft is a little smaller and round 5mm VS 6mm so you may have to swap out to Emaxx driveshafts. That's what I'm runnning at least |
| | #11 | |
Thanks! BTW, what's the part number on those Emaxx shafts? Also, are you running the stock tranny or something else? Thanks again! | |
| | #12 | |
http://www3.towerhobbies.com/cgi-bin...&I=LXDDT2&P=ML And the driveshafts: http://www3.towerhobbies.com/cgi-bin...?&I=LXSP55&P=M As I said in my previous post, this yoke will need to be drilled or bored out to 5mm to get rid of the flat sides on the inside, so they can fit the differential pinion gear shaft. | |
| | #13 |
| Pebble Pounder Join Date: Jan 2008 Location: midvale, Utah
| This is better.... includes a locker.... http://rcpcrawlers.com/product.php?p...&cat=23&page=1 |
| | #14 |
| | #15 | |
Awesome | |
| | #16 |
| why is that? |
| | #17 |
| A copper alloy ring and pinion VS Hardened steel. I don't know about you but the little I know of metallurgy, hardened steel seems to be a lot stronger and harder metal and should outlast a copper alloy by a long run. But that's just my .02 |
| | #18 |
| No need for the locker...I've already done the poor man's locker...aka epoxy. Which is probably half the reason the rear diff pinion teeth are rounded off... Looks like I can get by with stock shafts for now it'll just be a little loose. I'll wait to upgrade shafts when I do a crawler conversion... |
| | #19 |
| Well, without knowing what copper alloy they used, (there are some that are really strong/resilient) or what type of steel was hardened (you can harden 1018 mild steel... but its still 1018 mild steel) its foolish to say one will last 2X as long as another... but thats just my $0.02.... Also, one byproduct of hardening is that it makes metal brittle... so teeth could chip off easier. |
| | #20 |
| Well give both a shot in a brushless rig and get back to me |
| Thread Tools | |
| Display Modes | |
