Thread: HPI Crawler Conversion Kit
Old 02-20-2008, 11:17 AM   #1
Default HPI Crawler Conversion Kit
Does anyone know exactly what it does with the battery and servo? I couldn't tell from the press release on the main page.
-Ari
CrawlinROCKS is offline   Reply With Quote
Old 02-20-2008, 12:11 PM   #2
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
they move the chassias around to where the battery box is in front but the steering I don't know.
they probably either lengthened the steering rod or you just mount the srvo to the axle
demonoid369 is offline   Reply With Quote
Old 02-20-2008, 12:21 PM   #3
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I'm thinking they move the servo to the rear and flip it with a new servo mount.
Locked Up is offline   Reply With Quote
Old 02-20-2008, 12:26 PM   #4
Their servo mount looks like mine did after i did some cutting. I would say the servro stays in the same place just goes to the other side. The easier solution to this problem is to just do an axle mount for it and be done with it.
dragnz24 is offline   Reply With Quote
Old 02-20-2008, 04:40 PM   #5
Nebie here so go easy on me, but does anyone make a axle mount for the servo. If so can you please provide a link. Thanks.
Rock_abuser is offline   Reply With Quote
Old 02-20-2008, 05:17 PM   #6
Make your own King crawler!
Rock crawling is the latest RC craze to hit 4-wheel vehicles, and instead of the high-octane, adrenaline-fueled craziness of drifting from Japan, this low-speed, thrill-packed off-road adventuring comes from the mountain areas of America!
So what is crawling about? In stark contrast to the often two-dimensional world of circuit racing and drifting on pre-made, unchanging tarmac tracks, crawling gets you to attempt the improbable by attacking near-vertical cliffs, slick rock faces and piles of mountain rubble! Boulders, rock piles, mountain trails and footpaths are the typical location for competitions or fun meetings. Although in competitions the truck owners compete against each other, the magic appeal of rock crawling is that each driver competes against their own abilities, trusting in the strength of their equipment and the machine that is bringing them up the hill.
To make crawling more accessible to HPI customers, we’ll be releasing a sweet ‘crawler conversion’ made especially for the Wheely King!
The Wheely King has proven to be extremely popular with hobbyists, and it’s also become a great project truck for crawling enthusiasts to start a custom crawler build with. To make things even easier for crawling maniacs to get started, the Wheely King Crawler Conversion kit has everything that’s needed to convert a 4WD Wheely King into a ‘King crawler’!
The kit includes everything necessary to extend the wheelbase of the Wheely King, which will make it easier to go over obstacles. Extra lower shock mount positions allow you to fine-tune the suspension action for increased traction at both ends of the truck. A bolt-on gear set reduces the gear ratio of the Wheely King to give it more low-end torque to climb over anything. Finally, the chassis is flipped around so the battery is at the front, putting the weight just where you need it to get over and across whatever stands in your way.
  • Complete conversion kit for Wheely King truck – turn any 4WD Wheely King into a hill-climbing monster!
  • Chassis reversed to put battery weight over front axle
  • Extended wheelbase (2.25 inches longer)
  • Aluminium links
  • Extra climbing power with reduced gearing
  • HPI custom beadlock 3-piece wheels
  • HPI crawler tyres
  • Front and rear locked diffs for extra traction
  • New link and shock mounts on axles
  • Can mount servo in standard location or in front of truck
  • Savage body mounts included to fit Savage & monster truck bodies
  • 17mm hex hubs included to fit Savage & monster truck wheels
Extended Wheelbase
For extra stability when crawling up steep inclines, the conversion set includes new longer links that extend the wheelbase significantly over the stock Wheely King. Cool anodized aluminium links with tough pivot balls control the linkage and actuation, giving you loads of articulation for extreme angles!
Super-Low Gearing
To give the motor enough torque to get over boulders, rocks and any other obstacles, the conversion kit will include gears that will drastically lower the drivetrain gear ratio. This makes the Wheely King much slower on level ground, but you will get the full effect of the engine as you encounter steep approach angles and slippery, sandy rocks!
Cool Custom Beadlock Wheels
All-new HPI beadlock wheels will be included to give the Wheely King crawler a sweet custom look and allow you to change wheel weights, foams and tyres whenever you need to. There's nothing like the look and style of real beadlocking wheels, and these new 'mag' style wheels look amazing and perfect for the ultimate sclae crawler look!
New Lower Shock and Link Mounts
To give you the best tuning options, HPI designers have included a new lower shock and link mount with several extra mounting locations. This gives you a multitude of options for tackling the toughest climbs, inclines and rock piles.
Monster Truck Body Mounts
For getting a cool custom style, you can't beat the option of attaching different bodies on your crawler. We've included a full set of Savage-size body mounts for fitting dozens of different monster truck bodies! Simply use your Savage or other monster truck body right on, quick and easy, for a quick style change!
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
With the HPI Wheely King Crawler Conversion, you’ll be able to get right out and get crawlin’, or build up the project crawler of your dreams!
Wheely King Rock Crawler Conversion
Full conversion kit for Wheely King, with beadlock wheels, tyres, reduced gearing set, complete hardware and full instructions. Get ready for some monster crawling action!
Specification May Be Subject To Change
SnoopMaxx is offline   Reply With Quote
Old 02-20-2008, 06:16 PM   #7
Thats a nice kit but I called HPI today and they said two months before that even hits the streets.
Old 02-20-2008, 06:57 PM   #8
Location: at the bench of the up 'n coming '79 ford crew cab
well somone should tell them to hurry up!! haha
clod & bruiser is offline   Reply With Quote
Old 02-20-2008, 07:55 PM   #9
^^ i hear ya man i hope they will sell the parts individually but for some reason i just dont see that happening
resetpunk is offline   Reply With Quote
Old 02-20-2008, 09:23 PM   #10
Did they give you any clue on a price? I'm trying to decide if I want to wait for this kit, or start buying parts to build my own.
kwkride is online now   Reply With Quote
Old 02-20-2008, 11:54 PM   #11
Locked Up's Avatar
I wonder what the tires will be like?
Old 02-21-2008, 01:42 AM   #12
I asked the guy on the other end about price and he said they didn't have info on it yet
Old 02-21-2008, 04:12 PM   #13
he's right I hope to! there axle mounts for the links are cool and I'd like to be able to buy them! does anyone know where I can buy mounts for the links on my axle?
