Thread: Axle mount for the steering servo
Old 02-20-2008, 06:20 PM   #1
Default Axle mount for the steering servo
Does anyone make a bolt on kit to do this. Or does it need to be custom made? Thanks for your help
Rock_abuser is offline   Reply With Quote
Old 02-20-2008, 06:36 PM   #2
www.rcguy.com for the mounting bracket
You can also look at STRC for the links, but not sure if those will fit...
Better custom made them : very easy and cheap with 6-32 threaded rod, traxxas rod ends and alum tubing.
Good luck
Filibuster is offline   Reply With Quote
Old 02-20-2008, 06:40 PM   #3
http://www.tcscrawlers.com/Visionary...t-p-16805.html
2JSC is offline   Reply With Quote
Old 02-20-2008, 06:40 PM   #4
Theres also the complete steering at ckrc crawlers, heres the link http://www.ckrccrawlers.com/shop/ind...products_id=23
evilbluebunny is offline   Reply With Quote
Old 02-21-2008, 05:46 PM   #5
Cool thanks for the link. Has anyone tried this setup before. Does it work well. The links look real close like they might touch.
Old 02-21-2008, 06:23 PM   #6
Your welcome, and i bought this and the links do not touch they just look like they do by the way that they took the picture.
Old 02-21-2008, 06:31 PM   #7
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Plus, both the drag link and tie rod are mounted over the knuckle in that pic. If there WAS any kind of interference of the links, you could just move the tie rod to the bottom of the knuckle leaving the drag link on top. It would however net some clearance loss to the tie rod.
Offroader5 is offline   Reply With Quote
Old 02-21-2008, 07:03 PM   #8
It's a good price, but how good does it work. you still running it on you WK now?
Old 02-21-2008, 07:40 PM   #9
I still use it and it works awesomeand it was easy to put together.
Old 02-21-2008, 07:53 PM   #10
Well, thanks again. Going to order it right now. What servo are you tunnning on it?
Old 02-21-2008, 08:02 PM   #11
right now i am still using the stock servo, haven't been able to decide which servo I want to buy
Old 02-21-2008, 09:59 PM   #12
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I suggest these for price and power:
http://www.jpcustomrcs.atomicshops.c...75/5381533.htm
Just out of curiosity for those running the ckrcc kit .... doesn't the servo hit the shock?
Locked Up is offline   Reply With Quote
Old 02-21-2008, 10:57 PM   #13
uh, I dont think it would, but I wouldn't know since i didn't buy this till I made my widow chassis
Old 02-21-2008, 11:22 PM   #14
Good eye Locked up, have you heard of the servo hitting the shocks?
Old 02-21-2008, 11:25 PM   #15
Well I went to ckrcc site and found this picture. Looks like it clears.
Old 02-22-2008, 12:58 AM   #16
Locked Up's Avatar
I agree but it also looks like they relocated the shocks from the factory position on the axle end.
Old 02-22-2008, 03:13 AM   #17
Damn you have a good eye. Well they were out of stock so I guess it was a good thing I didn’t get it. I guess it's back to looking for another solution.
Old 02-22-2008, 11:12 AM   #18
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
he's right they did turn it 90 degrees, but the shock location is also different to! it's not on the shock tower. you need a servo mount that places the servo directly in the middle and on top of the axle.
demonoid369 is offline   Reply With Quote
Old 02-22-2008, 11:36 AM   #19
Heres mine. I made it out of some 1/16" aluminum. I used some traxxas rod ends and 8/32 rod. Only took a little time and it was alot cheaper than ordering one. Its been working really good so far. I just had to take that little bumper/brace out in the very front for clearance.
BigHoss is offline   Reply With Quote
Old 02-22-2008, 02:12 PM   #20
Heres one to consider. I have it on mine and i'm very happy with it
http://www.neweramodels.com/item.cgi...=&part_id=8887
has everything you will need plus good instructions
Issyt is offline   Reply With Quote
