Thread: servo arm?
Old 02-21-2008, 05:24 PM   #1
Default servo arm?
are there any ervo arms that will fit on the stock servo? or anything because i dont want to pay 14$ for a servo saver and scrap the rest.
bigblazerboy is offline   Reply With Quote
Old 02-21-2008, 08:18 PM   #2
I just test-fit the servo accessories that came with my Futaba radio... they fit just fine. I test fitted the stock HPI servo saver to a Futaba 9304 and it fit just fine as well.
So, if it fits Futaba servos, it should fit the HPI servo.
Pete from Houston is offline   Reply With Quote
Old 02-21-2008, 08:53 PM   #3
well for now i drilled a hole in it and put a scew in it. it locks it and will work until i get a new hitec 645mg servo when it dies.
Old 02-22-2008, 06:44 PM   #4
Did you snap that little ring with the gap in it, like i did? Now im waiting for the little peice that comes with a bunch of other crap for $15, or what ever the price is. i made a OTA mount but i need to get a WB extension or a new frame of some sort(widow).
RockCrawlingKid is offline   Reply With Quote
Old 02-22-2008, 06:53 PM   #5
The little plastic C on the stock servo broke while I was out bashing (no mods, it is still stock). Probably 1.5 - 2 hours of use. Instead of fixing the stock steering I'm working on moving the servo to the axle.
kelly_and_brian is offline   Reply With Quote
Old 02-22-2008, 06:59 PM   #6
Any Futaba horn should fit the stock servo. I ordered a couple of aluminum Duratrax horns from Tower when I broke the saver for the second time. I'd much rather replace a cheap servo instead of a piece of plastic.
2JSC is offline   Reply With Quote
Old 02-22-2008, 08:16 PM   #7
my servos on the axle. it was the little ring. i was going to buy a new one but thought why not just lock it untill i get a new servo. it broke when i was bashing and hit a thing of bricks by my house.
