| | #1 |
| Quarry Creeper Join Date: Oct 2007 Location: Ohio
| I got about $40 that I'm going to spend on my wheely king. I dont know what to get. Any suggestions? It already has custom chassis clocked motor plate servo mount rcguy lockers MG946R aluminum steering linkage duratrax esc eflite 1500mah brick batteries axial beadlocks m3 mashers evader shocks soft springs integy 55t lathe motor 18t pinion 96t spur some stick on weights and other odds and ends. Last edited by LST022752; 02-25-2008 at 05:30 AM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2007 Location: mountains of ca
| maybe a new body? got pics? |
| | #3 |
| | #4 |
| Quarry Creeper Join Date: Jun 2006 Location: um, Houston?
| How about a tank of gas in the 1:1, some water and trail mix, and heading out to a new crawl spot? Sounds like your WK is set up well and just needs to be driven! |
| | #5 |
| Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
| diff lockers if you dont already have em...... even if you got it locked with jb weld.... i would still buy the lockers if ya got the $$$ to burn.... my jb weld turned to dust after a while, had to switch to the lockers..... or get the heavy duty cvd's..... or like pete said..... gas up the 1:1 and go explore..... |
| | #6 |
| I got lockers. I know I forgot some stufff. |
| | #7 |
| Quarry Creeper Join Date: Feb 2008 Location: Dasmarinas City, Cavite Philippines
| $40 will cover the shipping to my place, lol Seriously, it looks and sounds about perfect. Maybe a new lid or like they said above $40 will give you about 1/2 a tank of gas(in my case anyways) and find some new bashing grounds or just hit you favorite. |
| | #8 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| How about a dig setup? Servo will be about $20 Servo mounts $2 That leaves $18 for rod ends, allthread & some misc nuts...which is plenty. You can reuse your factory steering arm and do it like mine... if you still have the nub on your tranny and the arm. |
| | #9 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| x2, I'd go with dig |
| Thread Tools | |
| Display Modes | |
