| | #1 |
| Newbie Join Date: Feb 2008 Location: Canada
| Sponsored Links | |
| | #2 |
| | #3 |
| | #4 |
| | #5 |
| | #6 |
| Pebble Pounder Join Date: Jun 2007 Location: somewhere
| Looks really heavy so far. But, I like the diamond plate chassis. |
| | #7 |
| Heres the latest: Covered links with brake line Bent the lower links in the front Attached shocks Made These extended drive shafts check out the COG on it so far. I also ordered an outrunner Brushless motor for it and a 12kg metal gear servo ![]() Put a stainless bolt and some nuts through yoke so when I poured the epoxy in shaft it would engulf itt ![]() epoxied the other end in place and used pipe cutter to make brass tapered tight around plastic ![]() ![]() ![]() ![]() |
| | #8 |
| | #9 |
| I joined the Band! Join Date: Feb 2008 Location: Lancaster
| What's the wheelbase on this thing? |
| | #10 |
| | #11 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| Well, I will definitely give you an "A" for originality, and coming up with some fresh Ideas! How some of them are going to work, however, I dunno. I think that you are going to be finding yourself constantly re-tightening the nuts on your upper link/plate thing. (not sure what to call it?) I would at least take them back apart and put a nut on BOTH SIDES where the rods go through the flanges. That should help. Also, the way you have this thing set-up (and knowing the stock WK shocks quite well) it's going to have a TON of flex, way more than you actually need. You could put a shorter set of shocks on it (like T-maxx shocks) and it would make the COG lower and limit the flex to a useful range. It would drop the ride height some, and you would lose a little center clearance, but that wouldn't even come close to being an issue. But overall, not a bad looking first effort. It's definitely different. Even if you never change a thing I still dig it. Two thumbs up. |
| | #12 |
| Rock Crawler Join Date: Aug 2007 Location: In my shop
| Looks pretty cool if you are going for a scale look. If you are going for competition your weight will really hinder you. Ideally you should be able to lay your truck on it side and it should sit on you wheels only. If it rools onto its lid your center of gravity is too high. Dig the treadplate though |
| | #13 |
| Thanks guys, The advice and compliments great and very much appreciated. When I get all the electronics in and give it a test run I will hack as much aluminum away as I can. I also plan on replacing some nuts with nylocks and the others will be loc-tited. |
| | #14 |
| | #15 |
| AWESOME! TOTALLY AWESOME! ![]() Join Date: Oct 2007 Location: gervais
| thats a really sweet ride! two |
| | #16 |
| | #17 |
| | #18 |
| Rock Stacker ![]() Join Date: Jan 2008 Location: Southern IL
| Great work! Very cool looking body, and it seems to crawl well. -Ari |
| | #19 |
| Thanks, I got the diffs locked up so now the crazy glue aint cutting it .Now I have to make beadlocks |
| | #20 |
| Thread Tools | |
| Display Modes | |
