Thread: RC4WD Extension Kit
Old 02-27-2008, 06:56 AM   #1
Default RC4WD Extension Kit
More pics to come
Starting off
Rock_abuser is offline   Reply With Quote
Old 02-27-2008, 09:45 AM   #2
Looks like they revised the kit. Mine used allumimum threads that were part of the links. So they bend and arent replacable. Whats the overall WB of that? Mine was 13.75" I since replaced the links with ones I built and cut 3/8" off the upper links, to shorten it to 12.25"
I wasnt impressed with the RC4WD Extention kit at all, but yours looks better then my original version did.
blackfoot is offline   Reply With Quote
Old 02-27-2008, 01:26 PM   #3
SCALE PERFORMANCE PARTS
Locked Up's Avatar
The short kit was worse. Not only were the links crap but the upper link was to narrow and didn't fit
They kept saying they were going to send a new "updated/retooled" kit but after 6 weeks I got my money back.
Not to turn this into a RC4wd bash thread but out of 5 things I have ordered from them 3 didn't fit right the first time or were machined poorly. Their straight axle conversion and shafts are quite nice though.
Locked Up is offline   Reply With Quote
Old 02-28-2008, 12:21 AM   #4
cutlaSS's Avatar
I also have the RC4WD extended WB kit, I bought it when I first planned on getting a Wheely King. After reading more about Wk's on here, I learned the RC4WD kit wasn't the greatest but since I already had it I installed it. I haven't ran my truck yet but I already don't care for the 13.75 WB and the lower links. So when I have to replace the lower links I'm gon shorten the truck. Blackfoot, did you have to redrill and tap the upper link when you shortened it? It looks like a good place to mount my battery so I want to keep it.
cutlaSS is offline   Reply With Quote
Old 02-28-2008, 04:08 AM   #5
There is over 1/2 inch of threaded hole in my uppers. I used an old 3mm screw and screwed it all the way in till it bottomed out. Then used my dremel and cutoff to cut around till I carefully bumped into the screw. I cut around .25 or so off each upper. Just back the screw out and the threads are still clean and untouched. I have mine shortened up to 12.5 now.
Old 03-01-2008, 09:12 PM   #6
I have this same kit but i am confused because i dont have instructions. I was wondering if you can give me any info to help me? Thx
bigboi is offline   Reply With Quote
