Thread: 7 Cell In Wk
Old 02-27-2008, 11:39 AM   #1
Default 7 Cell In Wk
Firts off, I've searched and not found anything helpful, so...
My 2 sons are wanting to get new rc trucks. One wants a fast truck while the other would like to build a crawler. What my thinking is, get the one a Stampede and the other a Wheelie King. The Pede mentions using a 7 cell. Could a guy also use a 7 cell in the WK and share the packs between the 2 trucks?
asfasasu3 is offline   Reply With Quote
Old 02-27-2008, 11:46 AM   #2
Absolutely, its only 8.4v compared to 7.2v. Now much more then that on a stock ESC can start to cause problems. But you wont have any issues as I run a 7 cell in my WK with the stock ESC everyday.
blackfoot is offline   Reply With Quote
Old 02-27-2008, 01:21 PM   #3
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Yes.
I ran 7-cells on my WK all the time. I actually ran mine on the stock ESC with 7 cells, higher than stock gearing and a 20t motor. the ESC eventually got hot and shut down but when it did it on regular gearing I had no problems.
Locked Up is offline   Reply With Quote
Old 02-27-2008, 03:14 PM   #4
you'll need to get a higher turn motor if you don't want to worry about the ESC shutting down. I used a 7 cell with my stock electronics for about a week before the overheating problem got too annoying, so I bought a 55T motor and never looked back. Now, I have the rx and esc in a semi sealed plastic box, a 7 cell 1800mAh battery and it hasn't overheated once.
jbrandt is offline   Reply With Quote
Old 02-27-2008, 03:20 PM   #5
What battery configuration were you running? I didn't think a 7 cell would fit in the stock holder.
John82601 is offline   Reply With Quote
Old 02-27-2008, 03:33 PM   #6
yes you can use 7 cell no problem ... y put my 7 cell battery on the front with tie wraps
andres-tavares is offline   Reply With Quote
