| | #1 |
| I joined the Band! Join Date: Feb 2008 Location: Lancaster
| This is my first RC build, goals for this is to have the ultimate rock crawling machine. Capable of getting wet. Pictures: ![]() ![]() ![]() Update 1: Extension Kit installed... ![]() Measures about 12 3/4ths... ![]() ![]() Update 2: Widow Chassis Completed. Chassis was plasma cut by me, from 3/32's steel. I need to make custom links next. I am waiting for shock mounts, thus the reason the are not hooked up. ![]() ![]() ![]() ![]() I decided to put the stock wheely king parts on it for now, until I get time to make my links... ![]() ![]() Update 3: RC4WD Rock Bull Pro 2.2 Chassis: ![]() ![]() ![]() ![]() More to come!!!! Update 4: R2 Tranny Installed.. Reciever hooked up.. ALMOST READY!!! ![]() ![]() ![]() ![]() ![]() Pictures where taken at my LHS... yeah I know it's a sick setup!!!! Parts Ordered: -RC4WD Extended Wheelbase Suspension Kit. - received -RC4WD Rock Crusher X/T 2.2 Tires. - received -2.2 Mudrock Beadlock wheels. received, not using -CKRC 120mm Threaded Aluminum Shock set.received -CKRC 15T 48P Pinion.received -Hpi 96T Spur Gear.received -Integy Rock Crawler Professional Motor 55t.received -4951x Traxxas E Maxx Drive Shaft Set.received -12mm to 12mm 3/4" Wheel Wideners. - received -Axial AX10 Locked Transmission Set #AX30487. - received -Visionary Fabrication Aluminum Wheely King Servo/Battery Mount. - received -Hitec 5645MG Servo. - received -Visionary Fabrication Upgraded AX10 Motor Plate.received -Kreepy Krawler Lock Jaws.received -Castle Creations Sidewinder Electronic Speed Control.received [b]Parts I will be Ordering: With those parts installed it should work good and be pretty cool, right? Thanks for looking and stay tuned for more to come!! UPDATE:!!!!! Change of plans!! Chassis: RC4WD Rock Rider Pro Chassis. received Found a brand new one, on ebay $75 shipped!!!! Still wraped in original packing material!!!!!! Transmission: RC4WD R2 Transmision. received Wheels: 2.2 Mayhem Inc. Double Phatty's. received Going all out!!! Last edited by rebman; 03-25-2008 at 08:44 PM. |
| Sponsored Links | |
| | #2 |
| bump. |
| | #3 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| Bump. |
| | #4 |
| Quarry Creeper Join Date: Aug 2007 Location: Casper, WY
| For the adapters check with the vendors listed on the site. I think a few of them carry what you're looking for. |
| | #5 |
| Kinda bummed, no parts came today.. tommorow a bunch should be here.. does anyone know if the Axial AX10 Locked Transmission Set will fit in with the stock chassis? Thanks for the help John! |
| | #6 |
| Rock Crawler Join Date: Dec 2007 Location: USA
| | #7 | |
| Quarry Creeper Join Date: Jun 2007 Location: Del mar
Forget the wideners, the Wheely King axles are wide enough. If your trying to get the most out of your truck with the stock as possible stuff you need a better chassis. Check out my rig. That is a Visionary Fabrication full option rig. It does much, much, better than my previous setup that I spent alot of my hard earned money on. to go about getting it Pm Billet Works, he will set you up. | |
| | #8 |
| Thanks for all your help, I've heard of guys running this MTroniks Viper Marine 40 ESC. How does it work out? I would like to crawl in some wet conditions, but I don't plan on running it in water alot.. How does say a Novak ESC-Rooster Crawler hold up to some wet conditions? |
| | #9 | |
| Newbie Join Date: Feb 2008 Location: Spring/Woodlands/Houston
dude your build sounds just like mine, same tires and rims even haha....i have the rooster esc on mine and it does very well, tho i dont go flyin thru the water and sloppy mud it still gets pretty damn dirty | |
| | #10 |
| Haha, thats crazy! I hope it looks decent, and performs well! A bunch of stuff will hopefully come tommorow, so stay tuned!!! |
| | #11 |
| Hey, does anyone know if the Axial AX10 Locked Transmission Set will fit with a stock chassis? |
| | #12 |
| | #13 |
| Well I guess I'll be buying/making a chassis... |
| | #14 |
| Pebble Pounder Join Date: Jan 2008 Location: Lanexa,Va
| i though you were gonna make a widow? |
| | #15 |
| Im debating what I want to do... I'll probably make something, they are simple to make.. Now im up in the air for transmissions.. You can put a dig on the Axial AX10 Llocked transmission right? |
| | #16 | |
| Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
| if you plan on gettin the rig pretty wet or runnin through some soupy mud.... get the viper..... i plugged the holes in my stock tires just so i could literally float it across the creek...... it will float for a minute without pluggin the holes, but it will start to sink after a minute..... it will still run underwater with the viper on it...... as far as the tranny, the stock wk tranny is a good tranny if you lock it...... i think there is a sticky about how to lock it..... really easy to do....... Quote:
| | #17 |
| How does that ESC do with regular crawling though? Can you provide a link to the thread about the tranny's? Thanks!! |
| | #18 | |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
Rebman, will this be a comp rig? The chassis you run is irrelevant if you are going to keep the stock tranny and motor setup (IE not offset the motor). The stock chassis is actually nice and light for what it is but with the motor up high the COG is not ideal. So you end up running it lower (droop or cut springs) and then you drag the belly everywhere. If you don't have a skid you get hung up everywhere and the cursing begins. Having said that, I have done quite well with mine once I installed the dig setup and did some tweaking. If you have no fab skills (not saying you don't) the stock chassis doesn't leave you many options though. I think I probably took the stock chassis as far as anyone else on here, if not further. I've got tons of tech writeups on my site if you decide you don't wanna drop coin on a new chassis and you want to run the stock chassis till it biodegrades. If you go after another chassis I advise you to not get one that is just an alum variant of the stock setup because you will be wasting your money. Alum is no lighter than the nylon/plastic the WK comes with. Although Usmc8541's chassis looks F'n sweet, he is seeing benefits from moving the battery/electronics to the front axle, angling the shocks, the little brushless motor (helps COG) and the curved links ... all of which you can do on the stock chassis. If you do leave the stock chassis system, be prepared to keep nothing but your axles. While I'm preaching .... Get yourself a cheap TQ3 and RX so you can run the dig. Then get some Proline M3 (Moab/masher) or Losi Claws. Those RC4wd tires look killer but as far as crawling goes they aren't anything special. Last edited by Locked Up; 02-28-2008 at 10:48 AM. | |
| | #19 |
| RCC Addict ![]() Join Date: Sep 2007 Location: Westland, MI
| Replacing the chassis and reconfiguring the motor/trans mount, will make better use of the drive train. The WK drive train is great. The chassis is the only thing holding it back, when it comes to crawling. Last edited by hitman46mod; 02-28-2008 at 11:37 AM. |
| | #20 |
| I'd like to match up with the comp. requirements. but I don't think i'll be competing with it.. I just got my RC4WD Extended Wheelbase Suspension Kit, and let me tell you... I am not Impressed with it at all so far.. poorly designed, to say the least. |
| Thread Tools | |
| Display Modes | |
