| | #1 |
| Rock Crawler ![]() Join Date: Dec 2005 Location: Hawaii
| Last week I picked up a ARTR Wheely King and I'm attempting to build a competent crawler/basher. My first mod was installing a RC4wd extended WB kit I bought in anticipation of getting a Wheely King. The only thing I really like about the kit is the upper link looks like a good place to mount my battery. After the extention I installed some AX10 Rock Lizards and beadlocks that I also bought before I got the actual truck. I'm waiting on my servo mounts and the rest of my electronics. Getting a 645MG, TQ3 (possible 4WS), 55 turn lathe motor. I still undecided on wich ESC to get, not gonna be a hardcore crawler so probably a Tazer or something. I also need to get a battery, I was thinking of a 2/3 6 cell from cheapbatteries to mount on the upper link. Gotta do some research on using 2/3 cells. Some other mods I'm planning on doing soon are deleting the stock battery and servo trays and replacing them with some crossmembers. I'm also gonna try dovetailing the stock body. I'll take pictures so if it comes out nice I'll do a small write up. Pics of the truck as it sits now will be up as soon as I download, I thought this site could host pics. |
| Sponsored Links | |
| | #2 |
| | #3 |
| Quarry Creeper Join Date: Jan 2008 Location: Portland OR / SLC
| sounds like you got some good plans for that wk. i dovetailed my stock wk body turned out ok. how u plan on doin it? |
| | #4 |
| | #5 |
| Kay small update, but no pics yet. While my daughter napped, I locked F/R axles with JB weld putty. I also removed the stock battery box and mounted my 2/3A 6 cell IB pack on the upper link. My shipment at the LHS was short so all I got was my 645MG and the afore mentioned IB pack. I decided to spent the extra cash and ordered a Mamba Sidewinder. I'm also waiting on my 55T lathe motor, TQ3, and Gecko R/C servo mounts. I still need to make steering links and rear lock outs. Hopefully I can get more done this weekend. |
| | #6 |
| | #7 |
| I joined the Band! Join Date: Feb 2008 Location: Lancaster
| Looks killer, do you plan on running a stock chassis? |
| | #8 |
| I'm gonna use the stock chassis for now, I wanna get the truck up and running. Last year I sold a coworker a TLT that I was building into a comp rig. He didn't use the Jefferson chassis I give him so I'm getting that back and moddin that to use with the WK but I'll probably change to a Pede or AX10 trans. |
| | #9 |
| Cool, yeah I got an ax10 coming.. |
| | #10 |
| Quarry Creeper Join Date: Sep 2007 Location: mountains of ca
| hey cool man. Nice job so far. Like the choice in bodies |
| | #11 |
| I got around to dovetailing the bed and front end, things weren't working out as planned so I didn't both taking pics of progress. It'll work until my Proline body comes in. Now I just need to work on my steering and my truck will be running. I'm having difficulty finding all thread locally so I was wondering if anyone knows of a correct length tierod/link from a doner car that'll work on the WK. |
| | #12 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| how do you like the ext wheel base kit? is it new style or old(new has sperate all thread old is one peice link mounts) |
| | #13 | |
Last night I found some all thread so I made steering links but still want to sleeve them. | |
| | #14 |
| Finally got to ruun my WK today, and I'm pretty happy with it's performance. The only problems I noticed were the lower link mounts got hung up a few time and the chassis also hung up. For the mounts I'm just gonna turn them so I can mount the links and shock to the front of the axle and I gotta made some kind of skid plate for the chassis if I don't replace it all together. I can also recommend the CC Sidewinder from personal experience. It performed smooth and trouble free. I just gotta get a Castle link to set the ESC more precisely. Oh, no pics cause I was too busy having fun. |
| | #15 |
| Newbie Join Date: Nov 2007 Location: Bellefonte
| Are you planning to add the third channel switch to the TQ3 when you get it? If so do you plan on using the article in RCCA to go by for instuctions? I just want to give you heads up that the # in the Mag for the switch is wrong. Dont know off hand what the correct # is but when I did get the correct one from Radio shack I found out it was not a switch that returned to center on its own. So I did some research and found one at McMaster Carr. www.mcmaster.com 7347K231 EachMiniature Toggle Switch, Dpdt, (on)-off-(on), 6 Amps At 125 Vac, Solder Lug It works perfect. It cost $7.87. Just wanted to give you heads up. I like my 4WS but it sure does roll easy when you do it at full speed. Nice truck you have. Mine looks alot like it but no dovetailing and both servos are on the axles (homemade using templates from Jowetts) and I used the STRC kit after I made my own like HPI suggested and decided I did not like them. I also used Pro line bead locs and M3 Moabs. Have fun. |
| | #16 |
| Worked on the suspension on my WK. Many of you know the RC4WD extended WB kit is too long to be comp legal but I found a fairly easy fix. I just swapped out the kit rod ends for Tmaxx ends, it's a direct swap. The only "hard" part is having to trim the upper link. The swap made my truck legal but then I decided I to clock the link/shock mounts so both could mount to the back of the axle this pushed me back over the comp limit but only by 1/4". But the truck seems to have benefited from this mod. The lower links are at a better angle and the ride height is lower but the truck seems to flex better. Hopefully I'll have a chance to test it out tomorrow. |
| | #17 |
| Well, I ran the truck and found my mods to be big failures. The truck hung up on everything and the torque twist is even worse. On some steep grades the lower COG helped but the bad out weighed the good. So my next round of mod include converting the rear to 4 link but leave the front as 3 link. I'm gonna raise the upper link mounts on the rear axle alittle higher so hopefully the IC will move more to the rear. Mount the shock more vertical and raise ride height alittle. Find out why my shocks are leaking and refill them with 30WT. Hopefully these mods will work beter than the first round of mods. |
| | #18 |
| Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
| Nice options so far, I suggest you change out the stock chassis though. Used ones are very avaliable around here, I got a used Thunderhorse for 10 bucks. |
| | #19 | |
| Newbie Join Date: Feb 2008 Location: Nakusp
| Quote: | |
| | #20 |
| That's just the pic from Proline, I thought the body looked good so I was planning on ordering it. I decided to get the normal C10, when it gets here I plan on dovetailing it like I did to the stock WK body. Crawlerguy851, I know the stock chassis is the WK biggest draw back. I plan on getting aftermarket chassis or make my own soon. |
| Thread Tools | |
| Display Modes | |
