Thread: alittle confused?
Old 02-29-2008, 10:15 AM   #1
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
Question alittle confused?
when you flip the chassis do you really need to flip the axle? especially if your going to get a servo mount for tha axle? cuz looking at it is seems that you don't need to do that because it's exactly the same on the other side?
info would be helpfull maybe a pic if you need to.
thanks
demonoid369 is offline   Reply With Quote
Old 02-29-2008, 10:39 AM   #2
I joined the Band!
Check out this:
Chassis Flip Guide
rebman is offline   Reply With Quote
Old 02-29-2008, 11:18 AM   #3
I've already seen this but I'm asking is, does it really matter if you flip the axle or not?
Old 02-29-2008, 11:37 AM   #4
I flipped my chassies and DID NOT do anything to the axles except lock the diffs. Just changed the wires on the motor. Seems to work just fine for me. And I did mount my servo on the axle also useing the Jowetts template.
USAFretired is offline   Reply With Quote
Old 02-29-2008, 01:58 PM   #5
Prick
rambuller84's Avatar
Flipping the axles causes the gears to rotate in the opposite direction. That's how it reverses. If you already have the truck apart, just flip the chassis.
rambuller84 is offline   Reply With Quote
