Thread: DNA Wheelie King Build
Old 02-29-2008, 07:40 PM   #1
Default DNA Wheelie King Build
Guys thought I would drop this in the forum aren't to many pics of the new VF Wheelie King Chassis Floating around.
There were a couple little issues. With RCP Crawler's Max clearance hubs and clockable axles, I needed to trim the Servo plates side mounts and the steering link needed to be bent ever so slightly to allow for full turning clearance. With stock hubs and axles neither of these would have been an issue.
Obviously, I still have a way to go.
stampedeproject is offline   Reply With Quote
Old 02-29-2008, 07:45 PM   #2
looks good, but why isnt it designed for the motor and tranny to lay down??!!!
gearmonkey23 is offline   Reply With Quote
Old 02-29-2008, 07:57 PM   #3
It's supposed to be a direct conversion for the WK so the Motor rides up top.
Old 02-29-2008, 08:11 PM   #4
Picky Fab'r/Acetal Junky
Offroader5's Avatar
I think you're getting a little too much flex out of it in that first pic. 95 degrees is too much
Offroader5 is offline   Reply With Quote
Old 02-29-2008, 08:26 PM   #5
very nice looking but think it would been better if motor and trans layed down?
rockeater is offline   Reply With Quote
Old 02-29-2008, 09:29 PM   #6
Absolutely! - the free articulation on the VF WK is sick.
I am thinking about using Revo shocks and doing a droop configuration, but still messing around with everything. The most obvious problem is ride height. Needs to drop by at least 3/4".
Old 02-29-2008, 11:24 PM   #7
Looks good so far. Your going to need some T-maxx shocks. I haven't tried Revo's but I think they will be too short. I tried Mini Lst's with some larger ends on them to lengthen them a bit, but they were still way too short.(3" eye to eye)
Visionary Fabrication Chassis "Vendetta"
Usmc8541 is offline   Reply With Quote
Old 03-01-2008, 04:21 AM   #8
Sick? I don't know about you, but I think that is a bad thing. Other than that, nice build.
Rock_abuser is offline   Reply With Quote
Old 03-01-2008, 09:36 AM   #9
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I wonder if we could trouble VF to make a "bolt on" dig assembly for us like they did the AX10?
Not that my setup doesn't work just fine but they make some good looking stuff.
How about it VF?
Locked Up is offline   Reply With Quote
Old 03-01-2008, 11:18 AM   #10
You can always limit articulation - that's a lot easier than the other way around.
Old 03-01-2008, 02:15 PM   #11
yea you can limit it as much as you want, plenty of options of articulation for people who want it tho. good job VF. anyone got a link to those lower links sold sepretly? whats VF home page?
phase10 is offline   Reply With Quote
Old 03-02-2008, 07:32 PM   #12
http://www.visionaryfabrication.com/
Old 03-02-2008, 07:35 PM   #13
Billet Freak
billet works's Avatar
How about it VF?
I dont wanna say too much but design is done and as soon as we can fit it in, prototypes will be built and tested. Did I say too much?
Don
VF
billet works is online now   Reply With Quote
Old 03-02-2008, 07:43 PM   #14
Billet Freak
Looks like you've done it well thus far Tony, we have given them proper articulation in a number of ways...again, limiting is easy once you get here. Suspension cycles smooth though doesn't it? Anyway, cheep and easy would be to just put some spacers or nitro fuel tubing inside the shock body beneath the piston. My shop "Bling King" (setup with 55 degrees of art.) runs the integy shocks in droop form and works awesome! Tony is right on with the intention of this chassis, any newb should easily be able to just bolt their stock WK stuff to this kit with no trouble and have something that will way out perform the stocker. Run a light weight brushless for power and the cg is honestly much lower than you would believe.
Don
VF
Old 03-02-2008, 07:43 PM   #15
Don,
While I have you online, What shock are you using shown on your site?
Old 03-02-2008, 07:50 PM   #16
Billet Freak
Don,
http://www.tcscrawlers.com/Integy-MS...R-p-16714.html
but we also have 3 VF WK's here with these
http://www.tcscrawlers.com/Hot-Bodie...1-p-16239.html
Old 03-02-2008, 07:58 PM   #17
Locked Up's Avatar
Don
VF
F'n A! Let me know if you need any testers. I'd be honored to beat on one and put up a review on my site.
If not, I'm in for preorder!!!!
Dare I push my luck? ...... How about some metal gears or a slipper eliminator?
Old 03-05-2008, 11:38 PM   #18
Guys need some group advice here.
Drop or Sprung on this chassis? What do you think.
Old 03-06-2008, 05:59 PM   #19
Either way is good, however, if I had the resources(Money), I would do droop. Partly because it would lower the COG even more than the new chassis already did, and because it would be slightly more controlled.
Droop it!!!!
Old 03-08-2008, 02:12 PM   #20
Droop it!!!!
I went with a droop style setup. The ProScaler's scale chassis rccrawler.ca (yes I typed it right) is just wrapped up recommended droop, but also supplied 4 Bic pen springs to go under the pistons - it worked great in conjunction with 80wt oil and external limiters. I just copied that setup and made a word of difference from a sprung setup.
The other change I made. Originally I assembled all the links with Emaxx link ends. That setup netted a 12.25" wheelbase, however the clocking was off. I just finished the tweak which was using longer Jato Link Ends on just one end of the front and rear upper links. This pushed out the wheelbase to 12.5" and corrected the clocking.
The final articulation ended up around 60 degrees however I still might tighten that up just a tad.
I will post pics later.
