Thread: axial links on a wheely king
Old 02-29-2008, 10:45 PM   #1
Default axial links on a wheely king
Has anyone try to stretck thier wheely king by using the links off the scorpion.Just curious I can build my own links thats not a problem but I was thinking the truck would look pretty cool with the green links.Also one more question everywhere I look for the length of the links to stretch it to comp wheelbase is in millimeters can someone translate it to inches thanks in advance starting my wk build this will be my first crawler build, racer turning rockstar thanks guys for any help you can give.
cdl822 is offline   Reply With Quote
Old 02-29-2008, 10:47 PM   #2
Sir Limps Alot
djjiz's Avatar
12.5" max wb. Hope that helps
djjiz is offline   Reply With Quote
Old 02-29-2008, 11:08 PM   #3
sorry maybe I worded it wrong I know the comp wheelbase I was hoping some one could tell me how long I have to make my links to extend it in something other than millimeters
Old 02-29-2008, 11:34 PM   #4
i havent used the axial links, but they are the same length as the STRC wheely king extension kit. they should work fine. only difference was the axial links are a little skinnier. do it i wanna see =P
phase10 is offline   Reply With Quote
Old 02-29-2008, 11:49 PM   #5
cool thanks I might give em a try if I do I'll try and post some pics
Old 02-29-2008, 11:57 PM   #6
right on, only thing i didnt mention are the axial link kit is more expensive and come with less parts then the STRC extension kit. but i dont kno how big of a difference it is.
Old 03-01-2008, 12:35 PM   #7
cutlaSS's Avatar
1 millimeters = 0.0393700787 inches
Found this conversion, if you still need it. But if you don't wanna make links, I'd go with the STRC kits.
cutlaSS is offline   Reply With Quote
Old 03-03-2008, 12:44 AM   #8
can anyone convert the length the aluminum tubing and all thread needs to be cut to build the links from millimeters to inches I looked everywhere and can't find it thanks for any help guys I appreciate it.
Old 03-03-2008, 05:30 AM   #9
google is nice to convert with.. just type something like..
12.5inches in mm
or
101mm in inches
etc etc
or use
http://www.onlineconversion.com/
HeatFire is offline   Reply With Quote
Old 03-03-2008, 02:44 PM   #10
Prick
rambuller84's Avatar
Search for a thread on links. Or, just start building. Cut them too long and mock it up. We'll help, but we're not gonna do the math and give you exact directions.
rambuller84 is online now   Reply With Quote
