Thread: Take Two.
Old 03-02-2008, 05:48 PM   #1
Default Take Two.
So last month I worked on a chassis made of a cutting board. Good start, but it wasnt straight and was pretty rough.
I had picked up two 20" American Chef cutting boards, then work got busy so I wasnt able to do anything until this weekend. I also used a rougher blade. That, combined with this new boards apparently higher melting temp, allowed me to cut much smoother cuts. I also changed the design ever so slightly from the last one in some area.
Mounted the servo on the chassis...I dislike the way axel mounted servos look. All the links are temporary.
Temp bod...
I still have to order body mounts and bumpers...among other things.
This is mostly to keep me busy and learn a little about building a custom RC while I decide on building a K2-3L to go under it.
SimpleGreen is offline   Reply With Quote
