Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: My First Build "WK Manta"
Old 04-22-2015, 11:27 PM   #21
Default Re: My First Build "WK Manta"
So its been a long time since I posted here but I'm still running the same rig with a few changes.
I have swapped the WK axles for the narrower Axial AX-10 Scorpion axles.
Steering servo is a Traxxas 2075.
Shocks are some aluminum body Traxxas shocks, I forgot the part numbers.
I ditched the WK ESC for a Traxxas XL-5 with LiPo cut off and waterproof.
Drive shafts are from a first gen Traxxas E-Maxx, no more ugly copper shafts.
Upgraded the receiver to a waterproof Spektrum 2.4Ghz SR200WP.
The Battery is a Turnigy nano-tech 2200mah 2S 40~80C Lipo, I get great run times.
I added a bunch of stick on lead weights in the wheels.
I also trimmed up the body a bit.
I'm thinking the next change I make is going to be a true 4 link setup. I'm looking at the Axial Bender Customs 4 Link Plate. Then I will Probably add an Axial AX-10 Scorpion Rear Steer Kit and Spektrum Waterproof 3ch Rx, since I will have the servo plate on the rear. Here are some updated pics. Next time I'm out on the rocks I'll get some action shots
chunk421 is offline   Reply With Quote
Old 04-24-2015, 09:49 AM   #22
I would reccomend a set of pitbulls instead of the rock lizards. Ive had both on wk crawler and there is no comparing. The pitbulls are awesome. Hank
hank the crank is offline   Reply With Quote
Old 04-24-2015, 01:09 PM   #23
who makes the pitbulls?
Old 04-27-2015, 06:48 PM   #24
Check out Crawler innovations in the vendors section. They are also discussed extensively in the tire section at the top of the page. Hank
