Thread: battery relocation and front weight
Old 04-29-2008, 09:36 PM   #1
Default battery relocation and front weight
can some1 link me to info on relocating the batt to the front. What are you guys using for weight in the front end when keeping the battery in the back?
Thanks!
prollynotjeff is offline   Reply With Quote
Old 04-30-2008, 09:53 AM   #2
Crawling is a fad...
Nerve's Avatar
Searching " relocating battery " you get this:
http://www.rccrawler.com/forum/searc...archid=1708885
Searching " battery relocation " you get this:
http://www.rccrawler.com/forum/searc...archid=1708894
Now it is up to you to thumb through those posts and do some reading.
Nerve is offline   Reply With Quote
Old 04-30-2008, 06:01 PM   #3
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I did my battery a little differently than most people so that I could run a front dig setup. Details and pictures are on my website (click the link in my sig)
As far as weights, I use Great Planes stick on lead weights in the wheels and on the axle.
Locked Up is offline   Reply With Quote
Old 05-02-2008, 03:43 PM   #4
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
for wieght on mine I use the fishing lead wieght that can be wraped around things, I just cut off 3 inch sections and wrap it on my axles.
demonoid369 is offline   Reply With Quote
Old 05-02-2008, 09:52 PM   #5
I had my chassis flipped, but put it back stock since my WK is more of a basher than a crawler. When I do go crawling, I zip-tie a coil spring for a CB antenna to the front bumper.
It's heavy but still stays out of sight and balances the truck nicely, even with the battery in the stock location.
Pete from Houston is offline   Reply With Quote
