Thread: Skid For WK
Old 05-04-2008, 04:37 PM   #1
Default Skid For WK
Hi Guys
I`ve been using my WK crawler for a week now and im loving it,
Only problem with it is the bottom of the chassis hooks up on the rocks not to much of a problem except its quite rapidly grinding through the chassis
So i think i need a lower skid does anyone have one fitted??
If so any piccies or plans would be greatly appreciated
Cheers
Adrian
Aij29 is offline   Reply With Quote
Old 05-04-2008, 07:59 PM   #2
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I went through two different setups...
First:
http://www.noeither.com/WK/tech/crossmembersliders.php
Second (and much improved):
http://www.noeither.com/WK/tech/skid.php
With the second one I just slide right over everything.
Locked Up is offline   Reply With Quote
Old 05-04-2008, 09:22 PM   #3
I went the quick-n-dirty route with mine:
I just ued some very thin aluminum (.040 I think) and used a spare chassis plate to locate the holes. I used a punch and hammer on wood to make the holes. Just pop the holes, bend the metal, and use the screws that hold the suspension and trans mounts to hold the skid in place. I used a small ball peen hammer to bend the leading and trailing edges up so they won't snag.
The aluminum is thin enough to show trail damage, which I personally think is cool.
Pete from Houston is offline   Reply With Quote
Old 05-05-2008, 08:42 PM   #4
yea i agree with pete..i like to see the damage well heres a pic of mine made out of some alum i had laying around and u can see the damage
resetpunk is offline   Reply With Quote
Old 05-06-2008, 08:38 AM   #5
Here's a picture of my old chassis with a skid plate made out of a piece of Meccano:
I'm now running a Widow chassis and you can't beat that slippery cutting board belly!!
The front skid plate (aluminum and delrin) is long gone as well.
SeanD is offline   Reply With Quote
Old 05-06-2008, 10:23 AM   #6
Sir Limps Alot
djjiz's Avatar
I used a thin scrap piece of plastic from under a Eclipse. Heated it up along the way and it fit real nice and slid instead of skid when done.
djjiz is offline   Reply With Quote
Old 05-07-2008, 04:13 PM   #7
u got any pics?
Old 05-07-2008, 04:44 PM   #8
Sir Limps Alot
djjiz's Avatar
Sorry, no pics of that setup. I can check the garage later and see if I saved it in my scrap stuff.
Old 05-08-2008, 12:18 AM   #9
Patterson Crawler
A_Jeeper's Avatar
I have one that I made up in AutoCAD. It has worked really well for me. I'm not at home right now. So sorry no pictures, but I can post some pic tomorrow. If you want the drawing let me know. Update: http://i29.photobucket.com/albums/c2...C/IMG_0664.jpg only one i can find right now.
jpg of drawing
http://i29.photobucket.com/albums/c2...ma/RC/Skid.jpg
A_Jeeper is offline   Reply With Quote
Old 05-08-2008, 07:51 PM   #10
I got tired of snagging everything, but all I had handy was a piece of old metal framing stud. I cut out a piece that was a little too big and then marked it out on the chassis and used my grinder to cut and shape it. Then I just used a small ballpeen to tap it into it's final fit right up against the tranny. It's been working pretty well so far.
Jake
Patella is offline   Reply With Quote
Old 05-09-2008, 06:51 PM   #11
I would like the drawing.
HndsWthtShdws is offline   Reply With Quote
Old 05-09-2008, 09:38 PM   #12
Patterson Crawler
A_Jeeper's Avatar
i know two of you would like a copy, but if there is any one else, pm me with your email and i will send it off.
I used 19 ga. alum. One because i had it around and two because with the breaks in it it didn't need any more then that.
picture of the first test fit.
http://i29.photobucket.com/albums/c2...attachment.jpg
Old 05-10-2008, 04:11 PM   #13
Hi
Thanks for the plans,
Saves me a load of trial and error
Thanks again
Adrian
Old 05-10-2008, 06:13 PM   #14
so it was just a test? are u going to keep that one thats in the pic? if not u can send that thing my way pm if u want to get rid of it or sell me one
Old 05-11-2008, 08:33 PM   #15
Patterson Crawler
A_Jeeper's Avatar
sorry man i already got ride of that one.
Old 05-11-2008, 08:39 PM   #16
well it doesnt hurt to ask but...r u willing to make another one and sell one to me?
Old 05-13-2008, 09:10 PM   #17
pm sent
Old 06-18-2008, 06:14 PM   #18
Patterson Crawler
A_Jeeper's Avatar
hey I drew up a new one that looks and fits much nicer. I'll post up a pic later if any one wants.
Old 06-18-2008, 07:34 PM   #19
I'd be interested in seeing it.
thanks
Old 06-18-2008, 11:36 PM   #20
Patterson Crawler
A_Jeeper's Avatar
these not a lot diff. it just look cleaner.
http://i29.photobucket.com/albums/c2...RC/skid001.jpg
http://i29.photobucket.com/albums/c2...RC/skid002.jpg
