Thread: need help with my trany
Old 05-04-2008, 07:33 PM   #1
Default need help with my trany
i am in a pickle i am not to shure what to do now i made a new chassie and i need help setting up the tranny and motor.now see the 2 nubs sticking up in the picture should i cut them off so the motor will fit on thair or should i make a new bracket?
ericbrierton is offline   Reply With Quote
Old 05-04-2008, 07:40 PM   #2
You HAVE to cut those posts off and grind them smooth to the case with a dremel to clock the motor, otherwise it won't get close enough to the gear to get a decent mesh and you'll be stripping spur gears all the time.
You'll also have to get a 96t spur gear (the stock 90t won't mesh when the motor's clocked.)
Cool lookin' chassis!
JavelinSST390 is offline   Reply With Quote
Old 05-04-2008, 09:45 PM   #3
ok but it is not the stock spur gear and will i have to make a new motor mount bracket?
Old 05-04-2008, 10:03 PM   #4
here is what I did
Easy clocked motor plate and mounting bracket
rockwerks is offline   Reply With Quote
Old 05-04-2008, 10:08 PM   #5
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Are you talking about the little ears on each side of the purple motor plate?
Offroader5 is offline   Reply With Quote
Old 05-05-2008, 02:51 PM   #6
no the little post sticking up off the side of the tranny
Old 05-05-2008, 03:34 PM   #7
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
couldn't you just cut open the one side to allow the moter to stick out slightly? I think offraoder5 had shown a pic of something like that before? it just never made it to the templates.
demonoid369 is offline   Reply With Quote
Old 05-05-2008, 07:37 PM   #8
Offroader5's Avatar
Cutting those posts off the top of the trans will do nothing as far as helping you get the motor installed...unless you are going to make a custom plate. You could either mount the motor in-line with the spur on top where those two closest posts are (which...yes you would have to remove them)...or you could do what many others have and clock up the whole trans like in the pic that Rockwerks posted. Either way, you're looking at making a custom motor plate.
Old 05-06-2008, 01:52 PM   #9
i wont to do what rockwerks did just leave one side with the things sticking up so i could mount it to the bottom of the chassie
