Thread: Anyone tried these links?
Old 05-20-2008, 12:43 PM   #1
Default Anyone tried these links?
Has anyone tried these links yet?
http://www.rcrockcrawling.com/produc...roducts_id=646
I just ordered them yesterday. I hope I can get them by the week-end, because we are planning on doing a little crawling Sunday.
broncobill is offline   Reply With Quote
Old 05-21-2008, 02:17 AM   #2
only down fall is that they were designed to be used on a stock wk chassis to give it 12.5" if you use them on a different cahssis that dose not have the same mounting holes you could end up too long or too short i had that problem with the strc extender kit. They look nice though
ruinx is offline   Reply With Quote
Old 05-21-2008, 08:38 PM   #3
Picky Fab'r/Acetal Junky
Offroader5's Avatar
Haven't tried them...but FYI, that kit is actually the RC4WD kit shown here.
http://rc4wdstore.com/product_info.p...roducts_id=699
Same stuff...but you can buy it directly from the manufacturer if you want
Offroader5 is offline   Reply With Quote
Old 05-22-2008, 05:29 AM   #4
I am using the WK chassis. I had made my own links out of threaded rod. 4-40 to extend the single mount upper link. But I kept on breaking it. Then I was going to make a 4 link out of 8-32 like my bottom links, then I seen the kit. So I figured I'd give it a try. Should be here today, or tomorrow according to USPS's web site.
Old 05-22-2008, 10:55 AM   #5
if you plan on comp ing and keeping the stock wk chassis then you will be fine
Old 05-22-2008, 08:23 PM   #6
SCALE PERFORMANCE PARTS
Locked Up's Avatar
The problem I see with the kit is that is extends the front & rear the same amount. I'd much rather have the back longer so the COG is pushed forward.
Locked Up is online now   Reply With Quote
Old 05-23-2008, 04:25 AM   #7
Location: ************************ Why crawl, when you can just jump up there?!
Did you notice that the stock WB on the WK is 9.4" and the rc4wd ext wb kit "says" it adds 88mm/3.46 to your wheelbase ?... If I do my math correctly... thats 12.86"... might be a misprint or i could be hook on phonix and not know how to read... or spell at that
http://www.hpiracing.com/kitinfo/10830/
nope i read it right...
ADDICT is offline   Reply With Quote
Old 05-24-2008, 02:00 PM   #8
I measured the axles before I put the tires on. 14" WB. There isn't any comps around here, so it's ok for now.
Old 05-24-2008, 02:06 PM   #9
i used that kit and i hated it, mine flexes like ill crap. i dont know if its mounted all wrong or what, but mine really sucks. my front axle BARELY hits 45 degrees. i plan on re-building it with a different chassis and custom links.
just my .02
LittleDave is offline   Reply With Quote
