Thread: Ultimate WK axles for my new super build
Old 05-20-2008, 05:28 PM   #1
Default Ultimate WK axles for my new super build
I have picked up all the parts from TSC (where else)
I surmised that since I was breaking inner and outer axle shafts I needed to go bigger if I where to build a super based on WK axles. So I did a little leg work and came up with this
Integy alum Castor blocks, alum CLOD knuckles, modified clod axle shafts cut to fit WK lockers and HD cut ring and pinions. TSC delrin shock mounts. 6 x 11 x 4 bearings to carry the larger diameter axle shafts, I still need to make custom spacers for the Knuckles out of teflon and cut down the king pins a tad.
has the same steering as a unmodded WK setup so a bit better than a clod
The overall width went from 8" to 8 3/4" about 1/4" narrower than a stock clod setup
rockwerks is offline   Reply With Quote
Old 05-20-2008, 05:49 PM   #2
OCCUPY RCC!
dezfan's Avatar
What about the flexing of the stock WK axle cases?
I've heard from more than a few that the case flex has caused them to strip their ring and or pinion.
dezfan is offline   Reply With Quote
Old 05-20-2008, 05:55 PM   #3
Remember the chassis design Im using? the cases will be fully trussed. and I dont believe that the cases flex enough to misalign the gears, its more a poor shimming job the sloppy cast gears. The super will also weigh no more than my 2.2 does and Ive had no issues with it (around 8 lbs) I tested the cases with the alum c's and housing braces in place and there is no more flex than the TXT housings
Old 05-20-2008, 05:58 PM   #4
OCCUPY RCC!
dezfan's Avatar
That's right, your running a BM style chassis.
Cool, looking forward to it.
Old 05-20-2008, 06:01 PM   #5
even still I tested the housing against a clod housing the axial housing and the WK flexes less without reinforcement.
Old 05-21-2008, 07:27 AM   #6
The Real Dogman's Avatar
ok I'm in! would like to see how this works out!!!
The Real Dogman is online now   Reply With Quote
Old 05-23-2008, 10:08 PM   #7
I knew we could get the dogman on a super! Good job rockwerks. I like it too. Kinda a budget super axle too.
fatbastard is offline   Reply With Quote
Old 05-23-2008, 10:11 PM   #8
I never said anything about building a super!! Just interested in making ultimate WK axles!! but you never know!!
Old 05-23-2008, 10:19 PM   #9
well I just got the clod axle shafts and modded them to fit the WK locker and it was easy! Ill do a full write up on it after I test them a bit
Old 05-24-2008, 12:23 PM   #10
crawl rookie's Avatar
Looks amazing rockwerks! very unique,
But.. why didn't you used txt axles?
You built a 2.2 txt once
crawl rookie is offline   Reply With Quote
Old 05-24-2008, 12:40 PM   #11
Prolly because he ALREADY did a txt!!
Old 05-24-2008, 01:39 PM   #12
yep a mono leaf sprung, juggy axled 2.2 this axle will have about 1 /4" better ground clearance at the pumpkin also
Just picked up a set of Xray shims for the knuckles.
Ill start building the super tonight. waiting on a few new parts
