| | #1 |
| Newbie Join Date: Oct 2007 Location: Martinez
| Ok so I ordered the Stage 1 Wheely King Crawler Kit from CKRC....... I got the kit today but im stumped beyond stumped, lol. I have the rods, tons of bolts and nuts but dont know how it all mounts up and I can't tell by the pictures. Also do I need to shave the drivelines down any? They seem to be too long...... Thanks for any help |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Sep 2007 Location: Duchesne
| yes you might have to cut the drive lines down a bit. but for the rest of it I don't know. |
| | #3 |
| Rock Stacker Join Date: Jan 2008 Location: LAURENS
| apparently they don't do directions. I changed out tranny gears and just had to reverse the disassembly. |
| | #4 |
| the longer links will be the upper links and the shorter links will be the lowewr links. thats the way it should be. |
| | #5 |
| ok I shaved the drivelines down some, I figured out the links but I need to know if I use the longer or the shorter bolts for them and which way the mount goes.....The longer bolts seem too long when using them for links under the tranny but too short if using them for the link in the rear that mounts up to the mount...... Thanks guys |
| | #6 |
| Rock Crawler Join Date: Feb 2005 Location: Oxford, MA
| I was thinking of getting one these kits. Kind of crazy that they don't include directions. |
| | #7 |
| Ok CKRC is sending me a new hardware bag.......hopefully it has the correct stuff, Thanks CKRC!!! I will keep you guys updated |
| | #8 |
| So far I have seen nothing in our mailbox from CKRC.....emailed them twice and I have received no response...... |
| | #9 |
| Received my new bag of hardware yesterday, correct bolts this time! Now after mounting the upper links using the longer links and then getting to the lower links they are too short......something else I need to do? Please help shed some light on this..... Thanks |
| | #10 | ||
| Quarry Creeper Join Date: Jun 2006 Location: um, Houston?
| | #11 |
| Running into some problems, its still cock-eyed..... Does the links bolt up to the highest hole on the mounts or the hole that is sticking out some? Thanks |
| | #12 |
| Newbie Join Date: Jan 2008 Location: Pollock Pines
| The longer links will be the lower links |
| | #13 |
| Yes I used the longer links on the bottom, short links up top, trimmed down the drivelines..... Still taking a look over and looking to see whats up. |
| | #14 |
| Can you post some pictures. It might help to identify the problem. |
| | #15 |
| Rock Stacker Join Date: May 2008 Location: I have to poop really bad
| Thread Tools | |
| Display Modes | |
