| | #1 |
| Pebble Pounder Join Date: Feb 2008 Location: Los Angeles, CA ( South Central )
| So i been looking to buy some but have no clue on what to get. I dont want to go balls out and get something pricey and i also dont want to get a junk set. So what have you guys found that works better than the stock suspension and wont leak like a defective maxi pad. found this but not sure http://www3.towerhobbies.com/cgi-bin...?&I=LXLVW1&P=0 |
| Sponsored Links | |
| | #2 | |
| Rock Crawler Join Date: May 2008 Location: ************************ Why crawl, when you can just jump up there?!
| | #3 |
| Rock Stacker Join Date: Mar 2008 Location: Greenville
| Agreed. The stock shocks leak like a sieve and the springs are too soft and can't counter the torque twist of a 55t motor. I recently picked up a set of these: http://www.ckrccrawlers.com/shop/ind...roducts_id=766 So far, I like them. I'm running the blue springs in the rear and the silver up front. I'm still fine tuning them which says a lot. They can be fine tuned!! Thread shock bodies ftw! I'm also running a stiff "clicker pen" type spring on the shock shaft of the rear left shock to help off set torque squat when I'm in a high degree, off angel climb. The extra shock helps some but also takes 10mm of compression off of that rear shock that I'm finding helps keep me from getting bound up. You know like when you give it throttle and the truck doesn't want to climb but instead wants to collapse on itself. LOL, I'm rambling. |
| | #4 |
| Rock Crawler Join Date: Oct 2007 Location: Vancouver, Wa
| I've been runnin' these for a few months. They work really well. http://www.jpcustomrcs.atomicshops.c...79/4462034.htm |
| | #5 |
| Rock Crawler Join Date: Jul 2007 Location: Rectalville
| I've been running the new RC4WD Dual-spring scale coil-overs for a while now and I love them. They're a bit pricey at $60 a set of 4, but they work REALLY well, and are just a hair shorter than the stock WK shocks which are too long anyway. |
| | #6 | |
| | #7 | |
where can i find said bigbre and how much? any links would be great! thanks for all the input guys. Ill have to post up some pics of my rig. | |
| | #8 |
| Quarry Creeper Join Date: Dec 2006 Location: dot com
| There is a set in the classifieds now. I am pretty sure rcp and tcs carry them too. Last edited by fatbastard; 05-23-2008 at 09:58 PM. Reason: DUMB |
| | #9 |
| | #10 |
| Prick ![]() Join Date: Aug 2005 Location: Bargersville, Indiana
| If you read the sticky..... it says you can't post in the for sale ads. PM's aren't hard to figure out. CLick the name, click send a private message, type your message and hit submit. Whooo... I almost broke a sweat. |
| | #11 | |
| Pebble Pounder Join Date: Apr 2007 Location: at the bench of the up 'n coming '79 ford crew cab
im running a set on my WK scaler. i run bigbores on my comp rig without the springs. both shocks work extreamly well and i like the dual rate setup on the rc4wd shocks super scale! i bought the bigbores for $50 at my lsh and the rc4wd's are $60 if i remember right. remember, anything is better than stock!! | |
| | #12 | |
im just lazy.... i like my life simple... blah, ill just buy some of off http://www.jpcustomrcs.com/home.html thanks | |
| | #13 | |
| Rock Crawler Join Date: Dec 2007 Location: USA
same here ive just been running 110mm | |
| Thread Tools | |
| Display Modes | |
