| | #1 |
| Pebble Pounder Join Date: May 2008 Location: Murrieta
| TVP with a tuber body had a full tuber and thought I would try to make it work better by building a "hybrid" TVP tuber I just can't get over how sic tubers look and I have fun working with brake line and it is alot cheeper then my 1:1 tube project's and so was the bender. Here is a list of the part's
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| Go upload the pictures to photobucket. |
| | #3 |
| Rock Crawler Join Date: May 2008 Location: ************************ Why crawl, when you can just jump up there?!
| | #4 |
| Newbie Join Date: Feb 2007 Location: Lincoln Co
| Yes we need pics |
| | #5 |
| built this tuber about a year ago and thought I would take all my R&D if u will and build a better one this tuber was 6 L.B the new one is 5.2 with all the same gear and a lower cog ![]() IMG]http://i282.photobucket.com/albums/kk272/Leeroy 26/DSCF1053.jpg[/IMG] eeroy26/DSCF1052.jpg[/IMG] Last edited by Leeroy; 05-24-2008 at 08:00 PM. |
| | #6 |
| Here is the clocked moter plate template from Harly0706 and did a little tweeking to it then I did a belly skid and layed out the TVP with alot of extra hole so I could fine tune it latter IMG]http://i282.photobucket.com/albums/kk272/Leeroy26/DSCF1070.jpg[/IMG] SCF1058.jpg[/IMG]![]() Last edited by Leeroy; 05-24-2008 at 08:06 PM. |
| | #7 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| | #8 |
| Sorry the pic are all jacked up I'm new to the pic thing and yes I know the is a little to muck flex will probably set it to about 60 |
| | #9 |
| | #10 |
| Quarry Creeper Join Date: Nov 2007 Location: barre
| looks to be ok height around 2.5 inches is good looks like 2.75 or so need some belly clearance or youll get high centered alot nice build looks good so far |
| | #11 |
| That pic is at full bump, I was trying a droop set up I'm not sure if I will keep it I also have alot of anti squat climes long steep stuff good but won't clime a curb very well and I'm going to vertical sepreration on both frame and axle side to combat duck walk AKA side steep I know the upper link are long enough |
| | #12 |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| | #13 |
| Ya I'm going to make new side plates that will lower the shocks. It would work great for droop but I'm probably going to go with standard susp set up with this truck. I was wondering how many 2.2 comp rig with drive shafts go with droop sus ? havent had much luck and I'm farly good with susp set up as far as shock oil spring rate and shock angle and effect maybe it my driving style ? |
| | #14 |
| | #15 |
| | #16 |
| pritty sweet Ha the good thing is un plug the battry and servo and u can pull the tranz which is requird to move the link mount's well I fixed that with the new set up |
| | #17 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Are the link end screws just threaded into the TVP plate? And the rear 4-link is just way out-of-whack. |
| | #18 |
| Yes they are screwed in why do u ask ? Am I looking for trouble with that set up? what side of the truck are u talking about? the link's are out of wack on the right side. the side with white spring's right ? cuz yes it is out of wak I was doing some anti squt testing and took it to the extreme and that is the front Last edited by Leeroy; 06-01-2008 at 01:29 PM. |
| Thread Tools | |
| Display Modes | |
