| | #1 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2008 Location: Edmonton, AB
| Cool! |
| | #3 |
| That Horror Movie Guy ![]() Join Date: Jan 2008 Location: Calabash, NC
| Awesome! Man, I hate those E-clips! |
| | #4 |
| Rock Stacker Join Date: Jan 2008 Location: Laurens SC
| That is a good write up. Let me know how those gear work out for ya. I know there is another member on here that has a set and his teeth are a little bent. Maybe he will see this and post up his dealings. |
| | #5 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| Ahh very sweet looking gears how many teeth are there on the top gear and the 2nd gear ? are they 14T/23T ? Regards |
| | #6 |
| Looks like the CKRC gears are 14t 21/23t 29t I believe stock is 14 23/23 28 It's hard to count all those little buggers! I have run a few batteries through them with no issues and without the slipper slipping. I have a comp this weekend and will update the writeup after that. Last edited by Locked Up; 05-29-2008 at 09:54 AM. |
| | #7 |
| Rock Stacker Join Date: Jan 2008 Location: LAURENS
| I'm the one with the bent teeth. I proceeded with them same steps as in the write-up. Great write-up by the way. I decided to lock mine up. The first or second time out I started to notice some noise mainly in reverse. I popped the tranny open and apparently while going forward it bent the teeth a little bit all of the way around. Therefore, making it not mesh as well in reverse. It still will work but I am afraid it will mess up more. I just can't decide if I should get another set of the aluminum ones or go with the more costly counterpart. |
| | #8 | |
Which gears have the bent teeth? Any pictures? | |
| | #9 | |
| | #10 |
| | #11 |
| Quarry Creeper Join Date: Jun 2006 Location: um, Houston?
| looking forward to reading your report! subscribed. |
| | #12 |
| Pebble Pounder Join Date: Jul 2007 Location: USA
| Looking forward to your comp report. I always enjoy your write ups. |
| | #13 |
| I had my friend Scott come with me to todays comp. He actually competed in my truck as well, so together we went through 6 total courses. It was Scotts first time touching an RC in years and he did pretty well once he settled in. I told him to not hold back in terms of using full throttle when necessary because I wanted to get a good break in for the gears and my new tires. I never heard the slipper do any slipping but we definitly had it bound up in several places. We ran Panthers and Claws and there was grip all over the place. Somewhere around the last gate he snapped a stubby and I know I wasn't being gentle either. The results ..... I'm not hearing ANY gear noise. Aside from the stubby and a fried dig servo the rig is running great. I'm hoping to open the case later tonight but I might not get a chance. When I do open it I'll update yall if I find anything interesting. For now, it seems like they will be up tp the task. |
| | #14 |
| Prick ![]() Join Date: Aug 2005 Location: Bargersville, Indiana
| I haven't had problems with mine. I'm running a 7T on 12 cells, so I'm putting them through the wringer for sure! |
| | #15 |
| when mine messed up I had put my twenty turn in just to play. |
| | #16 |
| Maybe yours were messed up from the get go? I dunno. I know my 7T Cobalt makes 5X the power a 20T can |
| | #17 |
| BLAKE59RT, what kind of grease did you put on the gears? |
| | #18 |
| Newbie Join Date: Jun 2009 Location: Fire base in Afghanistan.
| Just wondering if anyone knows where to get steel gears for the Wheely King transmission? I have searched most of the parts sites and have yet to find them. |
| | #19 | |
| Pebble Pounder Join Date: Jun 2007 Location: Mesa, Az
EDIT:Never mind, I found them cheaper http://www.ckrccrawlers.com/shop/ind...roducts_id=922 Last edited by thehopping1; 08-09-2009 at 04:49 AM. | |
| | #20 |
| Thanks for the links I guess the steel gears have been discontinued. What grease is everyone using with these gears? I have a EzRun 1000k bushless setup for it, installed on a SVP2 chassie with the motor clocked for a lower CG. Still waiting for the rest of the parts to get here so I can finish it and get to crawling. |
| Thread Tools | |
| Display Modes | |
