| | #1 |
| Newbie Join Date: Mar 2008 Location: transfer
| what dose clocking the axles do |
| Sponsored Links | |
| | #2 |
| Prick ![]() Join Date: Aug 2005 Location: Bargersville, Indiana
| It moves the pinion up to get a nicer angle for the driveshafts. |
| | #3 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| Getting the pinion up higher can also get your shaft out of harms way but take care to no go to far or your turning will suffer. |
| | #4 |
| ok then by cocking the axle all your doing is change the pion angle what dose that have to do with the steering |
| | #5 |
| Rock Stacker Join Date: Jan 2008 Location: Laurens SC
| if you put your axle c's on backward you will notice that the tires instead of staying flat in a turn they raise up on the outer edges of them. also i think it make the turning radius a little larger. I have had mine mound both ways. now the axle c's that RCP has I have no clue if those would mess with the steering. |
| | #6 | |
I doubt anyone is clocking their junk that much but for every bit your knuckles are past horizontal you lose a little bit of steering if you are running stock parts. | |
| | #7 |
| No one really clocks much now that the AX and WK have it built into the C's factory. And, the TLT's have enough aftermarket support to buy a clocked C. |
| Thread Tools | |
| Display Modes | |
