Thread: battery mounts
Old 05-30-2008, 03:21 PM   #1
AWESOME! TOTALLY AWESOME!
demonoid369's Avatar
Default battery mounts
Is there any templates or people's home creations that allow you to mount the battery on to the axle? it can be any battery but mostly the saddle packs. pics would be great
demonoid369 is offline   Reply With Quote
Old 06-02-2008, 04:44 PM   #2
come on I've seen someone who had a mount made up to hold battery's on the front axle, anybody?
Old 06-02-2008, 05:27 PM   #3
use the search function...
I believe I saw a bunch of templates in the stickies at the top...
jbrandt is offline   Reply With Quote
Old 06-02-2008, 05:54 PM   #4
aaah, it's for servo's correct me if im wrong.
RockCrawlingKid is offline   Reply With Quote
Old 06-02-2008, 05:59 PM   #5
VisionaryFab has a servo mount along with a way to attach a battery .
2JSC is offline   Reply With Quote
Old 06-02-2008, 07:56 PM   #6
Here's what I did - Pictures at post #6 and #15
New battery pack - charging question
Does this help?
SeanD is offline   Reply With Quote
Old 06-03-2008, 12:25 AM   #7
Here is some pic hope it will help It's ugly I know
Leeroy is offline   Reply With Quote
Old 06-03-2008, 01:29 AM   #8
thank you sean and leeroy but can you (leeroy) gets some close ups on the mount and how you made it? this what I was hoping for, not much on the wheely king for mounting battery's without having to buy a servo mount, maybe some vendors should start trying to produce battery mount for the wheely king
Old 06-03-2008, 06:44 AM   #9
I couldn't access my Photobucket last night so I was not able to post some pictures:
First I made new shock/link mounts:
Then I made two battery mounts that fit onto the top of the shock/link mounts:
The battery cells are held on with cable ties. These are sub c cells:
You could also try making this battery/servo mount. Its a design I came up with a number of months ago and served me well. I call it the Hammerhead (see the last image below)
Old 06-03-2008, 10:20 PM   #10
Actuly I have a new mount as of today I took the BTA mount I found at the same site as the "widow" and only used the side's not the center will try to put it up wed or thurs cuz my Girl friend is the one with the camara. My is for C cells there big but they last longer and there what I had so
Old 06-04-2008, 06:34 AM   #11
C cells??? They must make for one huge pack. My sub c's just barely fit on the axle so I can imagine how tight it must be with the c's. My pack is 4500 mAh so I'm pretty happy with the capacity/runtime.
